Home > Modifications & Maintenance (L663) > Tuning/remap d200 to d300
Page 5 of 7 <1234567>
mausau
Italy
Any new update?
Post #975936 29th Dec 2022 7:13am
irma
Anybody done this upgrade ?
Post #977971 14th Jan 2023 11:30am
Cedric74
Belgium
LR retrofit flash with oem soft, but if you need update of you’re soft…it’s gone !
Post #982099 11th Feb 2023 7:53pm
stevemfr
France
Sepp wrote:
'Old style' ecu tuning with additional electronics unit wired to the ECU and sensor harness still does work though. It's just very few suppliers left providing those as everybody has been jumping on the train speeding into the brave new digital world.
Tuning through a diesel through add on devices is not true tuning in that you are not optimizing fuel maps for efficient operation, you are simply tricking the motor into 'overfueling' under load. This is done through methods such as increasing fuel pressure at the injectors by reducing the pressure value provided by the sensor so that more fuel is injected during an injection cycle than the motor ECU has called for, or falsifying the signal from the motor temp sensor so that the ecu goes back to cold start mode, etc. These are the cars you see with black back-ends from the soot...
The only way to truly 'tune' a diesel is to alter the maps in the ECU (in theory, you could provide a complete 2nd ECU with alternative maps, but I have never seen this done. And it would be very expensive...)
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s,
2 FL1s and a L663 on the way
Post #982123 11th Feb 2023 11:41pm
vastine
Does anyone tried this?
Post #987296 30th Mar 2023 3:26am
tooth_dr
Northern Ireland
Had a look at the bluespark packs there. I’ve had two in the past - both worked ok, but caused limp mode when turned up too high.
I’m confused at the D300 box offering 364bhp. I thought the engines were identical, just detuned. Is this not the case?
Post #987433 31st Mar 2023 10:28am
hotwheels
May have some news soon
Post #1003029 4th Aug 2023 4:53pm
hotwheels
Just had the d300 map enabled by Chris at royles prestige and performance and what a difference it makes!!!! Lovely guy, genuinely knows his stuff, highly recommend!!!
Post #1004705 19th Aug 2023 7:40am
Moo
Ukraine
So what happens when there is a software update or it goes into LR for servicing. Does the Map get wiped? Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1004725 19th Aug 2023 10:14am
hotwheels
It’s your choice to have a software update and you can ask for it not to be updated however it should not change the map unless the service engineer specifically chooses to alter it which is unlikely I had activations done before and service did not make any difference
Post #1004727 19th Aug 2023 10:57am
ed11oad
D300 to D350
hi guys im a new member on here.
after buying a new urban 110 D300 back in april thinking it was the most powerfull diesel defender avaiable i have since found out that they make a D350.
no one seems to offer a power upgrade (remap) for the D300.
i dont really want a tunning module because they just dont deliver the stated power output.
any information or advice greatly appreciated
Post #1042286 9th Aug 2024 7:47am
SteveG
2005 Defender 90 Td5 CSW Belize Green
It’s very rare for them to routinely change fuel mapping files for sold vehicles, as they’d have to go to the expense and effort of retrospectively test the changes against previous versions of engine parts/ancillaries. So, typically the only risk you have of this happening is if you had to have some engine/ecu work done.
In the scenario that it did get wiped, you go back to who originally did the map file replacement and pay a labour charge to put the map file back in there.
Post #1042288 9th Aug 2024 8:07am
lightning
Re: D300 to D350
Do you find the D300 underpowered?
Post #1042355 9th Aug 2024 10:32pm
Crazymind
D300 is plenty. However it depends on your expectation and what you were driving before the defender.
The engine is a powerhouse, no matter the power!
Torque is limited by the gearbox to 700nm, 675nm the d300. You will not notice the difference.
You will notice the difference standstill acceleration and acceleration over 100 miles per hour.
My d250 is now d300 and is adequate to all the situations. 50 horses more they are always welcome Smile
Post #1042458 11th Aug 2024 12:56am
lightning
My D250 has plenty of reserve, even when towing the caravan.
However, l would happily upgrade the software to 300bhp if it didn't invalidate the warranty. But sadly it would.
As the same engine and transmission is supplied in some versions at 350bhp it would be fine with the extra 50bhp. l would only be prepared to do it with genuine Land Rover software though. After bad experiences with remaps in the past.
There is at least one company claiming to use genuine Land Rover software.
Post #1042559 12th Aug 2024 11:54am
