![]() | Home > Technical > Unsmooth TDCi |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 ![]() ![]() ![]() |
I Don't get rattle at all low rev's or take of.
------------ TDCI |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5082 ![]() ![]() ![]() |
Same with me.
Wasnt there a few with prop shaft bolts loose...could this be your problem? Mike |
austen Member Since: 11 Mar 2008 Location: Sydney Posts: 52 ![]() ![]() ![]() |
Checked the prop bolts - they are tight. I wonder if the handbrake issue has some connection? I have backed the adjuster off so that the brake lever is nearly vertical when applied, but it still may be rubbing. I notice that the gearchange clonk is sometimes absent after applying the brake and releasing.
Put it in low range 2nd last night and let it idle and the whole vehicle seems to vibrate. Back to the dealer, I think. Austen. |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
Mine also has a rattle noise still but I don't really feel it - just the noise as when my first clutch was replaced.
Seems to be coming back slowly. Puma 110 - gone Series III 1973 - going strong |
