Home > Technical > Unsmooth TDCi
austen
Australia 2008 Defender 110 Puma 2.4 SW Stornoway Grey
Unsmooth TDCi
My TDCi seems very unsmooth when accelerating from idle through about 1250 rpm. I realise it's only a four cylinder, but my wife's TD4 FL2 is like butter. The Defender's windows rattle until 1500 rpm or so. Is this the experience of others?
Many thanks,
Austen.
Post #5818 1st Jan 2009 2:27am
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
No problems with mine. Windows did rattle a bit on sever corrugations, but then so did everything else!
I don't get any rattle on take off or low rev's either. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #5819 1st Jan 2009 3:14am
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
I Don't get rattle at all low rev's or take of.
TDCI
Post #5823 1st Jan 2009 11:25am
mse
Same with me.
Wasnt there a few with prop shaft bolts loose...could this be your problem? Mike
Post #5832 1st Jan 2009 4:10pm
austen
Checked the prop bolts - they are tight. I wonder if the handbrake issue has some connection? I have backed the adjuster off so that the brake lever is nearly vertical when applied, but it still may be rubbing. I notice that the gearchange clonk is sometimes absent after applying the brake and releasing.
Put it in low range 2nd last night and let it idle and the whole vehicle seems to vibrate.
Back to the dealer, I think.
Austen.
Post #5864 2nd Jan 2009 10:11pm
CapeLandy
South Africa
Mine also has a rattle noise still but I don't really feel it - just the noise as when my first clutch was replaced.
Seems to be coming back slowly. Puma 110 - gone
Series III 1973 - going strong
Post #5884 4th Jan 2009 6:33am
