Home > Maintenance & Modifications > Front door seal recommendations?**UPDATE**
Page 3 of 3 <123
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
I had water coming in on the passenger side & changing the door seal made no difference, which was frustrating as hell! I sealed around the windscreen & still water was coming in, damn it! It's definitely a love hate relationship with my 110 at times & she never apologises for the trouble she causes me.
Then I replaced the little butyl pads which seal the gaps between the panels (under the seals) & that did the trick. Unbelievable! That was a couple of years ago & not one single drop of water ingress since.
This is the useful article that told me what I needed to do.
https://www.landrovermonthly.co.uk/article...ter-leaks/
Post #1003801 11th Aug 2023 7:13pm
the_lincs_landies
Thanks for your insight mate. I did do the water test with a watering can and the water is coming in too far back on the door to be the butyl patches. I tried pouring watering cans over the wiper splines incase it was the wiper wheel box. I tried the windscreen seals, the windscreen blocks, the lot, then as a last chance saloon I did the roof, which ran to the drainage channels… they ran off the front and hit the door (I also targeted the top of the door) and then I climbed in the drivers door to find this which, to me, was a bit of a smoking gun.
Post #1003810 11th Aug 2023 8:10pm
NickMc
There used to be a “Defender water ingress manual” you could download with all the leak points in it
Post #1003819 11th Aug 2023 8:45pm
the_lincs_landies
Yeah, I’ve got a couple of copies of it thanks. I’m pretty confident that it’s the seal at this point tbh, if it isn’t then I can recommence discovery
Post #1003822 11th Aug 2023 8:54pm
Plumbers91
United Kingdom 1989 Defender 110 200 Tdi HT Rutland Red
When you replaced the seals did you add any putty to the gaps where the tub joins the sides, and also sides to the roof? always a good idea to use a bit of gum gum putty and a bit of tape over the top of that. Stops it running down the inside of the seals.
Post #1003904 12th Aug 2023 8:42pm
the_lincs_landies
I haven’t replaced anything yet mate… car is as I bought it but will have to replace seal on passengers door it looks like. Will have a look at the gumgum idea when Indo this seal though 👍🏼
Post #1003910 12th Aug 2023 10:54pm
Co1
I think it’s called Dum dum. Autocorrect might have adjusted to gum!
Post #1003934 13th Aug 2023 8:32am
Plumbers91
Yes it did, autocorrect ey Laughing
This is the product I use atm.
https://www.frost.co.uk/eastwood-flexible-...placement/
Post #1004012 13th Aug 2023 7:44pm
poundnote
United Kingdom 2007 Defender 110 Puma 2.4 CSW Chawton White
I used aftermarket seals for the front doors but still leaking. just wandering if it would be worth biting the bullet and buying genuine seals
Post #1043188 19th Aug 2024 12:52pm
Linds Hanson
Definitely we don't fit anything other than genuine seals direct from JLR not Ebay
Post #1043442 21st Aug 2024 10:13am
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
The lincs landies
A couple of suggestions to try.
When my passenger door was leaking I built up a small amount of non setting mastic under the end of the front gutter. Bit trial and error, but it diverted the water off the front of the door top and side.
Also check that the door top is sealing against the top of the door seal. I could get my fingers in between the door top and seal. It is possible to bend the top of the door in if badly seated, but check the door adjustment first.
Expensive, but I have always replaced with genuine door seals, being careful to fit them as set out in the water ingress sheet ( I think). From memory , you start in the top right hand corner and work across and down, being careful to get a tight smooth fit at the mid door bends. The door seals are handed left and right too.
Post #1043447 21st Aug 2024 10:45am
Page 3 of 3 <123
