Home > Technical > fitting puma 90 rear seats in 90 TD5 |
Martyn668 Member Since: 17 Mar 2013 Location: Cambridgeshire Posts: 135 |
Sorry, no measurements, but if it helps, here is my guide to doing just that.
https://forums.lr4x4.com/topic/95342-how-t...e-puma-90/ |
29th Dec 2020 3:43pm |
Davepottsy Member Since: 27 Dec 2020 Location: Attard Posts: 5 |
thanks for your reply. unfortunately it is unavailable the pdf.
thanks again |
29th Dec 2020 5:35pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3470 |
Pm on your way. You can measure mine.
Frankly speaking, the Td5 opposite facing seats are a lot better than the forward facing seats, plus no need to butcher the tub to get the forward facing seats to fit a Td5. Puma tubs with forward facing seats are stepped, and have steel reinforcement plate to take the load from the seat. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
29th Dec 2020 6:51pm |
Thanks for your help, really appreciate.
29th Dec 2020 7:18pm |
Hi Davepottsy, I've uploaded the pdf to my gallery here on Defender2.net. So you can go and grab it from there.
30th Dec 2020 10:44am |
Thanks again for your help.
30th Dec 2020 5:36pm |
mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286 |
Hi - has anybody used a specialist to install Puma folding rear seats into a TD5 with the wheel arch conversion kit? 1964 Series IIA SWB Truck Cab - gone
1981 Series III SWB Hardtop - gone 1982 Series III SWB Hardtop - gone 1997 300Tdi Defender 90 Hardtop - gone 1983 Series III SWB Station Wagon - gone 1979 Series III SWB Station Wagon - gone 2007 90 CSW - gone 2010 USW XS - gone 2010 110 USW - gone 1959 Series II Truck Cab 1984 Series III CSW 2004 TD5 90 CSW |
16th May 2024 1:14pm |
I didn't (hence the build pdf), but I THINK CSK would do it. It was their part I fitted.
www.cskautomotive.co.uk |
17th May 2024 12:14pm |
