Home > Technical > fitting puma 90 rear seats in 90 TD5
Davepottsy
Malta 2005 Defender 90 Td5 HT Java Black
hi, i know that its been asked several times in this forum but i cant find a topic that it will give you the correct measures where to fit the seats exactly. i need help from someone own a 90 tdci with standard rear rear seats to send me the dimensions please. the only one i found is this picture that says 16" from the end of the tub. any better help will be appreciated. thanks.
Post #874811 27th Dec 2020 5:26pm
Martyn668
Sorry, no measurements, but if it helps, here is my guide to doing just that.
https://forums.lr4x4.com/topic/95342-how-t...e-puma-90/
Post #875043 29th Dec 2020 4:43pm
Davepottsy
thanks for your reply. unfortunately it is unavailable the pdf. Crying or Very sad
thanks again
Post #875069 29th Dec 2020 6:35pm
Dinnu
Pm on your way. You can measure mine.
Frankly speaking, the Td5 opposite facing seats are a lot better than the forward facing seats, plus no need to butcher the tub to get the forward facing seats to fit a Td5. Puma tubs with forward facing seats are stepped, and have steel reinforcement plate to take the load from the seat. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #875091 29th Dec 2020 7:51pm
Davepottsy
Thanks for your help, really appreciate.
Post #875097 29th Dec 2020 8:18pm
Martyn668
Hi Davepottsy, I've uploaded the pdf to my gallery here on Defender2.net. So you can go and grab it from there.
Post #875176 30th Dec 2020 11:44am
Davepottsy
Thanks again for your help.
Post #875266 30th Dec 2020 6:36pm
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
Hi - has anybody used a specialist to install Puma folding rear seats into a TD5 with the wheel arch conversion kit? 1964 Series IIA SWB Truck Cab - gone
1981 Series III SWB Hardtop - gone
1982 Series III SWB Hardtop - gone
1997 300Tdi Defender 90 Hardtop - gone
1983 Series III SWB Station Wagon - gone
1979 Series III SWB Station Wagon - gone
2007 90 CSW - gone
2010 USW XS - gone
2010 110 USW - gone
1959 Series II Truck Cab
1984 Series III CSW
2004 TD5 90 CSW
Post #1034927 16th May 2024 2:14pm
Martyn668
I didn't (hence the build pdf), but I THINK CSK would do it. It was their part I fitted.
www.cskautomotive.co.uk
Post #1035006 17th May 2024 1:14pm
