![]() | Home > Technical > fitting puma 90 rear seats in 90 TD5 |
Martyn668 Member Since: 17 Mar 2013 Location: Cambridgeshire Posts: 135 ![]() ![]() |
Sorry, no measurements, but if it helps, here is my guide to doing just that.
https://forums.lr4x4.com/topic/95342-how-t...e-puma-90/ |
Davepottsy Member Since: 27 Dec 2020 Location: Attard Posts: 5 ![]() ![]() ![]() |
thanks for your reply. unfortunately it is unavailable the pdf.
![]() thanks again |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3522 ![]() ![]() ![]() |
Pm on your way. You can measure mine.
Frankly speaking, the Td5 opposite facing seats are a lot better than the forward facing seats, plus no need to butcher the tub to get the forward facing seats to fit a Td5. Puma tubs with forward facing seats are stepped, and have steel reinforcement plate to take the load from the seat. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Thanks for your help, really appreciate.
Hi Davepottsy, I've uploaded the pdf to my gallery here on Defender2.net. So you can go and grab it from there.
Thanks again for your help.
mrwoo Member Since: 03 Jan 2008 Location: Cheshire Posts: 286 ![]() ![]() ![]() |
Hi - has anybody used a specialist to install Puma folding rear seats into a TD5 with the wheel arch conversion kit? 1964 Series IIA SWB Truck Cab - gone
1981 Series III SWB Hardtop - gone 1982 Series III SWB Hardtop - gone 1997 300Tdi Defender 90 Hardtop - gone 1983 Series III SWB Station Wagon - gone 1979 Series III SWB Station Wagon - gone 2007 90 CSW - gone 2010 USW XS - gone 2010 110 USW - gone 1959 Series II Truck Cab 1984 Series III CSW 2004 TD5 90 CSW |
I didn't (hence the build pdf), but I THINK CSK would do it. It was their part I fitted.
www.cskautomotive.co.uk |
