Home > Technical > Find the oil leak - Christmas Special!!
Page 2 of 2 <12
Co1
Good question. I’ve had a good sniff and it doesn’t smell like diesel.
Post #886470 19th Feb 2021 11:31am
You nose should be able to tell you if it is gear oil or engine oil too.
Post #886472 19th Feb 2021 11:38am
Dinnu
Is it only weeping from the belhousing? Although 1st pic shows oil stains already just below the starter motor... but could be just the oil stain getting larger.
Can you compare the colour of the oil weeping from the bottom of the belhousing with say a sample of engine oil from the dip stick?
The gearbox should not leak, even it is overfilled.. maximum overfill is to the fill plug. How it would affect the lubrication of the gearbox I do not know (I do not know if the MT82 is force lubricated, i.e with oil pump or just splash lubricated). I have never seen an oil pump in any of the MT82 manuals.
Mind you, the breather of the gearbox is into the bellhousing. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #886499 19th Feb 2021 1:03pm
Co1
My nose is probably good enough to tell between diesel and oil, but I don’t think it’s good enough to distinguish between oil types. Years of playing rugby and numerous broken noses later mean it’s is more form than function!!
I’m going to have a good look this weekend, as I relocated the file breather to the bulk head. I have checked the outlet and it is dry but perhaps it has been split somewhere.
Dinnu- it isn’t leaking from the bell housing hole itself, it is coming around from above and is on the engine block rather than the bell housing, I think. I’m going to give the area a through degreasing this weekend as best I can and see where it comes back.
Post #886537 19th Feb 2021 4:05pm
Co1
Cleaned the area up today. Then spotted this. It is coming from the bloody bell housing! It was doing it before the clutch change, which was why I got the crank seal done. The mechanic said he didn’t spot anything leaking from the gearbox side, but it only happens when warm so he might not have spotted it.
Anyway, before I take the gearbox out again I’m going to check how much oil is in it next weekend. If it had been over filled, could the pressure force it past the input shaft seal on the gear box?
Any help very much appreciated. Interestingly my fuel economy has been down since I noticed this leak. Over filled g’box = more resistance!
Post #886787 20th Feb 2021 5:37pm
Co1
Anybody help? Or any thoughts at all?!!
Post #886978 21st Feb 2021 6:15pm
L110CDL
I had this along time ago and it was due to a faulty / not well made crank shaft seal, i think since then my indy changed what make the seal was as he had a few like this, not good i know and i hope this is not your problem, but just a thought for you Co1 Neutral Clayton.
Keeper.
Post #887195 22nd Feb 2021 9:45pm
Dinnu
From the colour of the oil in that last picture, I think it is engine oil rather than gear oil. Even an over filled gearbox should not leak.... unless it is pushing the oil all the way up the breather (very unlikely).
The tdci rear crank oil seal cannot be installed incorrectly, however should use the installation collar/tool that comes with the seal. Otherwise can pinch the seal lip during installation.
I have replaced a crank seal on a Fiesta which was badly installed from factory. Hope that makes you feel better. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #887200 22nd Feb 2021 10:02pm
Co1
Thanks guys.
Post #887216 23rd Feb 2021 6:09am
Co1
Spoke to mechanic today who remembered doing the clutch as it was only a few months back. He took picks of the crank seal and gearbox seal as there was nothing leaking from either. He changed the crank seal anyway as the whole thing was disassembled. His view is that it is coming from above and tracking around the bell housing. The vac pump seal is done and given how poor access is at the rear of the engine what else could it be?
It’s likely to get bloody expensive from now on it, so I’ll need to make a call about living with it or shelling out. In terms of oil lost, it’s not much. The dipstick has gone from the top mark to about 75% so more than enough in and it gets a service in March.
Post #887333 23rd Feb 2021 7:04pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Mine has similar results and I've put it down to the crankseal to be changed at clutch/autobox decision.
I shall be watching this to see what you come up with
Post #887385 23rd Feb 2021 10:29pm
Page 2 of 2 <12
