Home > Technical > Find the oil leak - Christmas Special!!
Co1
Help needed! There is an oil leak coming from so where under the bonnet. The top picture of from under the engine. In the top of the pic is the dpf. The leak is coming around the seam of the bell housing from above. The bottom pic is from the top of the engine. There is wet oil residue in the circled area.
What do you think?!!
Post #874698 26th Dec 2020 1:03pm
Dinnu
Just behind where you circled on the lower picture is the vacuum pump. Perhaps it is the source? Not sure where the vacuum pump gets the power from, but very likely that it connects to the exhaust cam shaft. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #874702 26th Dec 2020 1:25pm
Co1
Thanks Dinnu, appreciate the quick reply. Sounds like a job for the garage then.
Any other theories out there?
Post #874704 26th Dec 2020 1:29pm
Dinnu
Perhaps it is part No2 in link below. Just guessing though. If it is, there does not seem to be any specialist work to replace, just access is restricted.
https://www.lrworkshop.com/diagrams/land-r...mp_2.2tdci 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #874710 26th Dec 2020 2:54pm
Co1
Nice one. I’ll check it out. Looks straight forward enough, will get the bonnet off later this week to get a better look.
Interestingly, I’ve lost a little bit of fuel economy in the last month or so. Any link to a vac pump leak?
Post #874712 26th Dec 2020 3:01pm
Dinnu
Possibly just 2 bolts. Perhaps no need to disconnect the vacuum hoses.
I doubt if it is leaking oil there will affect fuel economy.
Tyre pressures ok? When it gets cold, pressure drops. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #874714 26th Dec 2020 3:12pm
Co1
Had another look today and it looks like your are right Dinnu, so I’ll get one ordered up. Thanks a bunch. Install looks bloody awkward, I don’t think I’ll be able to get the pump off without removing the ecu as clearance looks to be bloody tight!
Post #874786 27th Dec 2020 12:11pm
Dinnu
👍👍 I think you are lucky that you do not have an AC refrigerant line passing right next to vacuum pump! 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #874788 27th Dec 2020 12:24pm
L110CDL
Hi Co1, not sure but in your top pic, where you have it circled, has the metal part broken/fractured away from the screw ?
or is it meant to be like that ? Clayton.
Keeper.
Post #875132 29th Dec 2020 9:55pm
DAZ110
Isn’t it that just a shadow front the metal part in front?
Post #875142 29th Dec 2020 10:39pm
Co1
It’s a shadow line from the bell housing flange into the dpf heat shield. Thumbs Up
Post #875160 30th Dec 2020 7:35am
L110CDL
phew Thumbs Up Clayton.
Keeper.
Post #875565 31st Dec 2020 10:00pm
Co1
Right then, we’re back for round 2! Finally got round to doing the vac pump seal last week and... it’s still leaking! There is oil dripping by the hole in the bell housing but not from it, it is coming from above and running round. It only does it when it is warm, not all the time.
The crank shaft seal was done a few months back when the clutch was done. I don’t seem to be losing much oil going by the dipstick.
Answers on the back of a postcard.
Post #886370 18th Feb 2021 6:13pm
Co1
If the leak was due to an overfilled gearbox, where would it leak out from? I seem to think I’ve had the leak since a service.
Post #886443 19th Feb 2021 8:48am
Are you sure it is lubricating oil not fuel? What does it smell like?
Post #886456 19th Feb 2021 9:42am
