![]() | Home > Technical > Find the oil leak - Christmas Special!! |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3701 ![]() ![]() ![]() |
Good question. I’ve had a good sniff and it doesn’t smell like diesel.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17620 ![]() ![]() ![]() |
You nose should be able to tell you if it is gear oil or engine oil too.
My nose is probably good enough to tell between diesel and oil, but I don’t think it’s good enough to distinguish between oil types. Years of playing rugby and numerous broken noses later mean it’s is more form than function!! I’m going to have a good look this weekend, as I relocated the file breather to the bulk head. I have checked the outlet and it is dry but perhaps it has been split somewhere. Dinnu- it isn’t leaking from the bell housing hole itself, it is coming around from above and is on the engine block rather than the bell housing, I think. I’m going to give the area a through degreasing this weekend as best I can and see where it comes back. |
Cleaned the area up today. Then spotted this. It is coming from the bloody bell housing! It was doing it before the clutch change, which was why I got the crank seal done. The mechanic said he didn’t spot anything leaking from the gearbox side, but it only happens when warm so he might not have spotted it.
Anyway, before I take the gearbox out again I’m going to check how much oil is in it next weekend. If it had been over filled, could the pressure force it past the input shaft seal on the gear box? Any help very much appreciated. Interestingly my fuel economy has been down since I noticed this leak. Over filled g’box = more resistance! ![]() Click image to enlarge |
Anybody help? Or any thoughts at all?!!
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10896 ![]() ![]() |
I had this along time ago and it was due to a faulty / not well made crank shaft seal, i think since then my indy changed what make the seal was as he had a few like this, not good i know and i hope this is not your problem, but just a thought for you Co1
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3489 ![]() ![]() ![]() |
From the colour of the oil in that last picture, I think it is engine oil rather than gear oil. Even an over filled gearbox should not leak.... unless it is pushing the oil all the way up the breather (very unlikely).
The tdci rear crank oil seal cannot be installed incorrectly, however should use the installation collar/tool that comes with the seal. Otherwise can pinch the seal lip during installation. I have replaced a crank seal on a Fiesta which was badly installed from factory. Hope that makes you feel better. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Thanks guys.
Spoke to mechanic today who remembered doing the clutch as it was only a few months back. He took picks of the crank seal and gearbox seal as there was nothing leaking from either. He changed the crank seal anyway as the whole thing was disassembled. His view is that it is coming from above and tracking around the bell housing. The vac pump seal is done and given how poor access is at the rear of the engine what else could it be?
It’s likely to get bloody expensive from now on it, so I’ll need to make a call about living with it or shelling out. In terms of oil lost, it’s not much. The dipstick has gone from the top mark to about 75% so more than enough in and it gets a service in March. Last edited by Co1 on 24th Feb 2021 6:03am. Edited 1 time in total |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 ![]() ![]() ![]() |
Mine has similar results and I've put it down to the crankseal to be changed at clutch/autobox decision.
I shall be watching this to see what you come up with |
