Home > Puma (Tdci) > Remap or not ! |
Alex von Staffeldt Member Since: 06 Nov 2017 Location: Copenhagen Posts: 57 |
Hi All.
I have a 2008 110 with remap. Im experiencing problems like a lot here in the forum with the car cutting off when driving up hill in 6th gear. I have over the last couple of years tryed to fix the issue, but with no luck ! I have changed a lot of components and added some to try getting rid of the issue. Yesterday i talked with a friend of mine who is working in the Danish Army as a mechanic about the issue. His oppinion is, since the problems with the car first started AFTER the Remap, that it would be better to get the original software back, as it seems something is not working in the remap. So, im considering to get it remapped back to original software, although i love the extra power, but am very confused about it cutting of every time i go up hill. What do you experts think of that ? Best regards from Denmark Defender 110 Puma 2.4 tdci |
16th Dec 2020 7:05am |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2039 |
Speak to Pete Bell at:
https://bellautoservices.co.uk/ |
16th Dec 2020 9:46am |
stew 46 Member Since: 26 Jan 2012 Location: Wadebridge ,cornwall . Posts: 561 |
+ 1 Pete Bell
16th Dec 2020 10:03am |
Bell auto will send you a gizmo to plug in and with the app will read what you have on there , you upload to pc and email the info to him and he can do what’s needed and email you a file back that you install etc
16th Dec 2020 10:20am |
I did the remap with Celtic tuning. I dont know if you consider it a reputable vendor. But my guess is there is something wrong if not done by proffessionals. Defender 110 Puma 2.4 tdci |
16th Dec 2020 12:01pm |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 |
Looking at Celtic Tuning website they will tune anything from a Tractor to a Lambo.
Pete Bell - Bell auto services specialises in Land Rovers, and having had his 170 +EGR delete tune on my 2.4 tdci for 80k+miles and it still puts a grin on my face Just because you're offended doesn't mean you're right. |
16th Dec 2020 1:41pm |
shropshiredefender !
I will definitely contact Bell for a remap.. After christmas.. Defender 110 Puma 2.4 tdci |
16th Dec 2020 3:17pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3676 |
+1 for Pete Bell. Probably the best in the business.
16th Dec 2020 7:15pm |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 484 |
Your friend is right. If you needed a reliable car, you'd better avoid any surprises caused by 3rd parties' design approaches. If it's just for fun / speed / power, well, give it a try & experiment some new kind of car design |
16th Dec 2020 7:47pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20376 |
Alive for me. I wouldn’t touch any lesser known tuner except for Alive or BAS as leaders in the field. I’ve ran my tune for about 6 years now with zero issues at all. $W33T $0U7H3RN $UG4R
16th Dec 2020 7:52pm |
Has any of you guys experienced that when going uphil in 6th gear, it cuts of ? Defender 110 Puma 2.4 tdci
16th Dec 2020 9:09pm |
Ive known poor performance in 6th gear and cutting out in low gears.
How old is the VCV? $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
16th Dec 2020 9:21pm |
custom90steve -
I havent changed the VCV. Should that be done ? Defender 110 Puma 2.4 tdci |
16th Dec 2020 9:26pm |
It could possibly be the culprit yes, putting the tube aside. The PF Jones ones are good. You can simply swap it and don’t need any programming or specialist equipment.
I did on mine and solved all the issues I ha e and brought a lot of power back. She felt like she needed pushing all the time before and lacked high end power. Your sun pots you’ve mentioned could simply be reversed, mine was cutting out in low gears. The VCV does do that and an erratic idle after very cold winter starting can also be a symptom but mild and disappears when warm. I would try it if it’s over 5 years old, defiantly if it’s original. Mine was about 11 years old. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
16th Dec 2020 9:48pm |
