Home > Puma (Tdci) > Yuasa HSB020 will it fit
Moz
Yuasa HSB020 will this shoe horn in 🤔 oh its a puma 2.4 as the old one is on its way out
Post #869752 26th Nov 2020 5:29pm
Dinnu
With a length of almost 40cm, not sure if it will go through the seat box... or at least that easily. I recently changed mine (2.2) and I think the original battery was about 34cm long. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #869780 26th Nov 2020 7:23pm
This one fits:
https://www.ebay.co.uk/itm/122851172675
This is the one I have fitted and is an upgrade on factory fit.
Very pleased with it. TheThunder Rolls🇬🇧🇺🇸
Post #869784 26th Nov 2020 7:39pm
DAZ110
....and it’s a bit cheaper here:
https://www.tayna.co.uk/car-batteries/yuasa/ybx5019/
Post #869789 26th Nov 2020 7:56pm
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
Brilliant information guys. I’m needing a replacement too Thumbs Up
Post #869794 26th Nov 2020 8:02pm
Nice find Daz, I’ve had it in a year now. Turns over great from stone cold.
Fits straight in, factory retainer clamps fit. Battery post clamps fit and breather tube connects up perfectly.
You can indeed tell it’s got that bit more power than my old one did. The old one lasted at least ten years. It has a battery state indicator too to show you when it needs replacing. Thumbs Up TheThunder Rolls🇬🇧🇺🇸
Post #869797 26th Nov 2020 8:07pm
DAZ110
I’ve got the same battery Steve. Thumbs Up
Fitted mine about a month ago.
Post #869803 26th Nov 2020 8:22pm
Post #869810 26th Nov 2020 8:57pm
kyvlle
United Kingdom 2004 Defender 110 Td5 XS CSW Epsom Green
+1 for the Yuasa 019 battery (I use it in my Td5)!
Post #869816 26th Nov 2020 9:50pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
Another for the Yuasa 5019 here.
Post #869850 27th Nov 2020 7:10am
Moz
Thanks chaps I was originally looking at the YBX5019 but just wondered if anyone had got the slightly bigger one in handy that they come with the 5 year guarantee as well whats it like dealing with tayna and warranty if it go's tits up ?lol my original has lasted 11 years so far just the short journeys to work in the dark then home in the dark are not helping the old girl
Post #869872 27th Nov 2020 8:57am
Joe the Plumber
I got my new Yuasa (on my 2014 van) to replace the original earlier this year as I found I needed to keep re-charging it. It's a bit higher CCA (900 vs 800) than the original.
But having charged up the original one again after I fitted the Yuasa, it seemed okay, so it's now installed on our narrow boat as the engine battery, and working fine!
Maybe it was lack of use (only short journeys), coupled with the alarm draining it constantly, that made it seem as though it was failing.
Post #869937 27th Nov 2020 2:49pm
kyvlle
Not to put a downer on the Yuasa YBX5019, I use it personally myself. The first one died just after 3 years, and Halfords replaced it under warranty with no fuss. Probably down to my usage pattern of mostly short trips.
Post #869974 27th Nov 2020 5:59pm
Moz
Think you might be right Joe lock down+short trips +starting+lights+blowers+subwoofer+alarm has taken its toll lol charged up fine and has been ok so far but put an order in for a new YBX5019 as she's about due a new one after 11 years hope the new one will do as well lol
Post #870328 29th Nov 2020 8:44pm
If you use LED lights then you won’t have as much current draw. Saves the battery and fuel.
That’s the perfect reasoning to upgrade to your financial advisors aka Wives. Laughing Snigger
I think most of us still put the heated seats on though. Very Happy TheThunder Rolls🇬🇧🇺🇸
Post #870339 29th Nov 2020 9:41pm
