Home > 130 > Moving to a 130
Page 3 of 3 <123
Dowks
United Kingdom 2015 Defender 130 Puma 2.2 HCPU Keswick Green
Hood on, very pleased with it fit wise. Also added a Mota Lita wheel to give me a bit more cabin space. Both rear door shedders full of holes so in order to stop the carpets getting wet
Trip out with the kids down a nice Sandy Lane today
Post #875873 2nd Jan 2021 3:29pm
For info when you sort out the rear door water shedders you may want to add an additional home-made shedder.
I found my rear floor was always getting wet when it rained, from water entering the door between the glass and the door skin (even with good seals there is a significant ingress. After puzzling about the door drainage for a while, I realised that the factory shedder actually directs water inside the vehicle! I added some conventional shedders cut from builders' plastic sheet (the sort used for a DPM in concrete floors) and taped it inside the door to direct water to the drain holes right at the bottom. Since doing this I have had no water at all in the back.
Post #875875 2nd Jan 2021 3:52pm
Dowks
Thanks for the tip. My shedders had loads of holes in where the previous owner had added checker plate bottoms to the door and mounted them with self tappers through the shedder...... plus the grommet for the window electrics
Will go get some plastic sheet, and more mastic!
Post #875907 2nd Jan 2021 5:46pm
JOW240725
That looks amazing, really like it! Nice looking lane too! James
Instagram @suffolk_rovers
Post #875999 3rd Jan 2021 8:26am
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Never af any leakage on the rear floor. The front however...
Post #876001 3rd Jan 2021 8:54am
Page 3 of 3 <123
