![]() | Home > Puma (Tdci) > 2008 2.4 Puma not starting - HELP! |
may be immobiliser not coms with engine ecm
may be the plug at the back instrument pack see below Martin post Last edited by dorsetsmith on 24th Nov 2020 11:07pm. Edited 2 times in total |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2298 ![]() ![]() ![]() |
Hello G4UJS
To spare any ![]() ![]() If after checking all obvious connections you think it maybe the Lucus 10AS Alarm describe the symptoms to Paul Brown... https://www.technozen-electronics.co.uk/ Good Luck SKIP https://www.defender2.net/forum/topic83242.html |
G4UJS Member Since: 20 Jan 2019 Location: Shropshire Posts: 226 ![]() ![]() ![]() |
I don't think it is fuel....the fuel light isn't on and its showing about quarter of a tank.
Its in the middle of my field at the moment so will look again in daylight. Not sure where I should be looking tho! Rob |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1822 ![]() ![]() ![]() |
In the daylight, go back to basics - has mud and stones dislodged a fuel line at the filter? Has it been so deep that something has dried and fell off onto the TDC sensor on the back of the bell housing? Are the under seat relays secure?
Good luck! |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6641 ![]() ![]() ![]() |
As it is de-immobilising and will crank, unlikely to be the 10AS.
Try the removing the instrument pack (Torx T30 needed I think) and bridging pins 3 and 4 of the plug with a paperclip or similar: https://www.defender2.net/forum/post814212.html ![]() ![]() |
Thanks for the input Martin.....instrument pack? Do you mean the dashboard dials?
Any photos? thanks Rob |
yes
Hi G4UJS
General order of approach...(taken when installing the XDefend) ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Instrument Pack is still plugged in above (Plug from memory is a 'rolling lock' in position so don't just pull it take a good look at 'release' mechanism) SKIP https://www.defender2.net/forum/topic83242.html |
![]() Click image to enlarge ![]() Click image to enlarge ![]() ![]() |
Thanks Guys
Martin/Skip.
if it is the instrument pack 3/4 will any faults have been logged. ta Rob |
Possibly, if the instrument pack isn't seeing the incoming immobiliser signal.
beyond my knowledge...(I'm also a student here
![]() https://www.defender2.net/forum/topic83242.html |
DTC
P160231 |
