Home > Puma (Tdci) > 2008 2.4 Puma not starting - HELP!
G4UJS
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
Hi all.... HELP!!
I've had a terrible day...... got big mower stuck in field in deep mud....took Land Rover over and got stuck, managed to winch both out of the mud.
Left the Land Rover ticking over in the field.
When I went back out to the Land Rover it had stopped?
I think I have an immobiliser problem.
The car still locks fine on key fob.... immobiliser flashes as expected then goes to the slow flash. When I open the car with the key fob there is no usual immobiliser light showing. Engine Cranks but will not fire.
I've tried locking and pressing lock many times to sync...doesn't make any difference
I've disconnected the battery and reconnected to no avail
Tried my second key fob....that didn't work either but it still locks and unlocks with it.
Any ideas please.
Regards
Rob
Post #869365 24th Nov 2020 4:19pm
dorsetsmith
may be immobiliser not coms with engine ecm
may be the plug at the back instrument pack
see below Martin post
Post #869372 24th Nov 2020 4:56pm
X4SKP
Hello G4UJS
To spare any Embarassed ...I trust you haven't run out of fuel Question
If after checking all obvious connections you think it maybe the Lucus 10AS Alarm
describe the symptoms to Paul Brown...
https://www.technozen-electronics.co.uk/
Good Luck SKIP
Post #869374 24th Nov 2020 5:06pm
G4UJS
I don't think it is fuel....the fuel light isn't on and its showing about quarter of a tank.
Its in the middle of my field at the moment so will look again in daylight.
Not sure where I should be looking tho!
Rob
Post #869380 24th Nov 2020 5:29pm
ickle
In the daylight, go back to basics - has mud and stones dislodged a fuel line at the filter? Has it been so deep that something has dried and fell off onto the TDC sensor on the back of the bell housing? Are the under seat relays secure?
Good luck!
Post #869382 24th Nov 2020 5:38pm
Martin
Site Admin
As it is de-immobilising and will crank, unlikely to be the 10AS.
Try the removing the instrument pack (Torx T30 needed I think) and bridging pins 3 and 4 of the plug with a paperclip or similar:
https://www.defender2.net/forum/post814212.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #869442 24th Nov 2020 9:23pm
G4UJS
Thanks for the input Martin.....instrument pack? Do you mean the dashboard dials?
Any photos?
thanks
Rob
Post #869449 24th Nov 2020 9:42pm
dorsetsmith
yes
Post #869470 24th Nov 2020 11:04pm
X4SKP
Hi G4UJS
General order of approach...(taken when installing the XDefend)
Instrument Pack is still plugged in above
(Plug from memory is a 'rolling lock' in position so don't just pull it take a good look at 'release' mechanism) SKIP
Post #869530 25th Nov 2020 12:03pm
Martin
Site Admin
2015 D90 XS SW
Post #869531 25th Nov 2020 12:13pm
G4UJS
Thanks Guys Very Happy Thumbs Up
Post #869532 25th Nov 2020 12:26pm
G4UJS
Martin/Skip.
if it is the instrument pack 3/4 will any faults have been logged.
ta
Rob
Post #869533 25th Nov 2020 12:37pm
Martin
Site Admin
Possibly, if the instrument pack isn't seeing the incoming immobiliser signal.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #869534 25th Nov 2020 12:38pm
X4SKP
beyond my knowledge...(I'm also a student here Thumbs Up) SKIP
Post #869536 25th Nov 2020 12:44pm
dorsetsmith
DTC
P160231
Post #869547 25th Nov 2020 2:31pm
