Home > Puma (Tdci) > 2008 2.4 Puma not starting - HELP! |
may be immobiliser not coms with engine ecm
may be the plug at the back instrument pack see below Martin post Last edited by dorsetsmith on 24th Nov 2020 11:07pm. Edited 2 times in total |
24th Nov 2020 4:56pm |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Hello G4UJS
To spare any ...I trust you haven't run out of fuel If after checking all obvious connections you think it maybe the Lucus 10AS Alarm describe the symptoms to Paul Brown... https://www.technozen-electronics.co.uk/ Good Luck SKIP https://www.defender2.net/forum/topic83242.html |
24th Nov 2020 5:06pm |
G4UJS Member Since: 20 Jan 2019 Location: Shropshire Posts: 226 |
I don't think it is fuel....the fuel light isn't on and its showing about quarter of a tank.
Its in the middle of my field at the moment so will look again in daylight. Not sure where I should be looking tho! Rob |
24th Nov 2020 5:29pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1782 |
In the daylight, go back to basics - has mud and stones dislodged a fuel line at the filter? Has it been so deep that something has dried and fell off onto the TDC sensor on the back of the bell housing? Are the under seat relays secure?
Good luck! |
24th Nov 2020 5:38pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
As it is de-immobilising and will crank, unlikely to be the 10AS.
Try the removing the instrument pack (Torx T30 needed I think) and bridging pins 3 and 4 of the plug with a paperclip or similar: https://www.defender2.net/forum/post814212.html 1988 90 Td5 NAS soft top 2015 D90 XS SW |
24th Nov 2020 9:23pm |
Thanks for the input Martin.....instrument pack? Do you mean the dashboard dials?
Any photos? thanks Rob |
24th Nov 2020 9:42pm |
yes
24th Nov 2020 11:04pm |
Hi G4UJS
General order of approach...(taken when installing the XDefend) Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Instrument Pack is still plugged in above (Plug from memory is a 'rolling lock' in position so don't just pull it take a good look at 'release' mechanism) SKIP https://www.defender2.net/forum/topic83242.html |
25th Nov 2020 12:03pm |
Click image to enlarge Click image to enlarge 1988 90 Td5 NAS soft top 2015 D90 XS SW |
25th Nov 2020 12:13pm |
Thanks Guys
25th Nov 2020 12:26pm |
Martin/Skip.
if it is the instrument pack 3/4 will any faults have been logged. ta Rob |
25th Nov 2020 12:37pm |
Possibly, if the instrument pack isn't seeing the incoming immobiliser signal. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
25th Nov 2020 12:38pm |
beyond my knowledge...(I'm also a student here ) SKIP
25th Nov 2020 12:44pm |
DTC
P160231 |
25th Nov 2020 2:31pm |
