Home > Technical > Loss of brake lights
Likeomg
Could anybody with some more knowledge point me in the right direction before I set off looking...
2.4 90, LED rear lights (proper SVX ones)
drove down to move a caravan into storage, drive down all okay, once we plugged the 13 pin caravan in with a adapter, brake lights stopped working.
- I checked my cctv of me leaving that morning and brake lights worked before I set off, also for the drive down, used my cruise control (mobile centre unit) - on the way back, when pressing the brake pedal cruise control did not disengage
Leading me to believe the brake switch has failed?
Any other suggestions? would a 13 pin trailer with adapter cause this or was maybe the switch just on the way out?
Post #868914 22nd Nov 2020 9:10am
Brake switch is the obvious conclusion although fuses would also be worth a check. Darren
Post #868930 22nd Nov 2020 10:17am
Likeomg
Fuses all look good, I’m going to dismantle now to confirm which switch to order, can’t work it out online Crying or Very sad
Post #868932 22nd Nov 2020 10:25am
dorsetsmith
LR032956
brake light
Post #868943 22nd Nov 2020 11:27am
Likeomg
thanks. been a bot of a effort to track one down in stock, have ordered online but not holding much hope ill see it soon, will call LR tomorrow
Post #868987 22nd Nov 2020 4:17pm
Likeomg
£4 from Land Rover, luckily was in stock too
Post #869115 23rd Nov 2020 1:12pm
dorsetsmith wrote:
LR032956
brake light
Again, top help Dorset, I'll never forget you helping with a resistor for my v8 Thumbs Up
Post #869130 23rd Nov 2020 2:06pm
