![]() | Home > Technical > Loss of brake lights |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2655 ![]() ![]() |
Could anybody with some more knowledge point me in the right direction before I set off looking...
2.4 90, LED rear lights (proper SVX ones) drove down to move a caravan into storage, drive down all okay, once we plugged the 13 pin caravan in with a adapter, brake lights stopped working. - I checked my cctv of me leaving that morning and brake lights worked before I set off, also for the drive down, used my cruise control (mobile centre unit) - on the way back, when pressing the brake pedal cruise control did not disengage Leading me to believe the brake switch has failed? Any other suggestions? would a 13 pin trailer with adapter cause this or was maybe the switch just on the way out? |
Brake switch is the obvious conclusion although fuses would also be worth a check. Darren
Fuses all look good, I’m going to dismantle now to confirm which switch to order, can’t work it out online
LR032956
brake light |
thanks. been a bot of a effort to track one down in stock, have ordered online but not holding much hope ill see it soon, will call LR tomorrow
£4 from Land Rover, luckily was in stock too
