Home > Td5 > New Defender 110 Owner - Performance and Starting Problem
Page 2 of 2 <12
4RF RDS
If you clean it up super good and the area is free of crud, go to your local crappy tire and get tube of the “right stuff” (permatex amazing sealant) and seal it up with that. Great product but make sure to let it day overnight. I did one like this that lasted years. What can make it last long is to cut a small contoured piece of sheet metal to fit over the end and glue it in place. It is possible to stop the leak this way but the real fix is usually remove the t-case and a new seal. Hateful job lying on your back but easily doable.
Good luck. Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #868699 20th Nov 2020 9:33pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
It all depends how bad the leak is.
Sealing from the outside works but it is not that easy. The shaft moves a little so the sealant will break loose, i made a small plate ans sealed that to the housing. That works good after multiple attempts.
The plate:
Use plenty off sealant so the plate seals to the transferbox housing and the gearbox housing. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #868754 21st Nov 2020 11:07am
Dobs
Canada 2004 Defender 110 2.5 TD HT Scotia Grey
This is exactly what my transmission guy is going to do (permatex right stuff) i should be good then !
For the rest, i’m waiting for the parts to come over from roversnorth
Post #869123 23rd Nov 2020 1:40pm
Page 2 of 2 <12
