Home > Td5 > New Defender 110 Owner - Performance and Starting Problem |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
It all depends how bad the leak is.
Sealing from the outside works but it is not that easy. The shaft moves a little so the sealant will break loose, i made a small plate ans sealed that to the housing. That works good after multiple attempts. The plate: Click image to enlarge Use plenty off sealant so the plate seals to the transferbox housing and the gearbox housing. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
21st Nov 2020 11:07am |
Dobs Member Since: 19 Nov 2020 Location: Quebec Posts: 9 |
This is exactly what my transmission guy is going to do (permatex right stuff) i should be good then ! For the rest, i’m waiting for the parts to come over from roversnorth |
23rd Nov 2020 1:40pm |
