Home > My Defender > Puma to LT1/8L90 Restomod
Page 26 of 41 <123 ... 252627 ... 394041>
mrfirepro
United Kingdom 1996 Defender 90 300 Tdi HT Bonatti Grey
Just re-read my previous post, I certainly wasnt being critical of the LS3 at all Embarassed
Anyway some electricary, anyone for spaghetti...
and both seat boxes almost full..eeeeek
Post #952807 17th May 2022 8:10pm
Pacha
Quote:
Any way some electricary, anyone for spaghetti...
Shocked Big Cry Rgds.
Chris
Post #952808 17th May 2022 8:36pm
JOW240725
That's the bit that scares me!! Shocked Bow down James
Instagram @suffolk_rovers
Post #952829 18th May 2022 5:00am
mrfirepro
got a friend to Tig the vacuum outlet for the oil catch can so I can finish the intake.
not sure if it’s a bit too closed to the AFM??
Finally got round to finishing the on-air suspension system and spent 30 mins online with them setting it up, I'll post a video when I get five mins of the heights, quite pleased with the whole process and it all worked flawlessly.
more stuff from YRM, no wonder we're on first name terms Laughing
trial fitted ...
T washed, ready for EM121
Finished article...well nearly no sealing strips (anyone know the parts numbers?)
Also, not sure if they (sill rails) should be body colour or not, anyone know??
floors in..
Also got round to fitting the underfloor panels which I forgot about until recently Embarassed
Post #954502 3rd Jun 2022 4:32pm
Co1
Great work Paul, let’s see some vids!
Post #954520 4th Jun 2022 6:58am
mrfirepro
Sorry it's not a bit more exciting. This is the on-air suspension system just commissioined.
2022-06-04 16-08-05 by paul darke, on Flickr
https://flic.kr/p/2npJ1ME
Notice how tidy my workshop is.....
Post #954547 4th Jun 2022 3:38pm
Dinnu
The sills are left unpainted on bare zinc from the factory. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #954548 4th Jun 2022 3:47pm
mrfirepro wrote:
... Also got round to fitting the underfloor panels which I forgot about until recently Embarassed
Has anyone ever figured out the purpose of these things and what, apart from collecting mud and grot, they actually do?
As far as I can tell they were only fitted to the XS spec models and I have to assume that they are Landrover's impressive attempt at sound proofing. It is hard to see any other purpose, and I have reservations about how effective they are at that.
My County-spec vehicle certainly never had them fitted and doesn't seem any the worse for not having them.
Post #954554 4th Jun 2022 5:14pm
Co1
It’s a good system; when the end of the day comes you can just sweep all your tools into a pile in the corner, ready for the following morning. Saves you spending a fortune on a snap on roll cab!
Post #954557 4th Jun 2022 5:23pm
CarMan
Agreed, but on my low mileage MY16 hard top (Corris body colour) they are looking not perfect and I have been thinking of having them ‘blacked’ with something, for purely esthetic reasons Rolling Eyes Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top (sold)
Post #954560 4th Jun 2022 5:51pm
mrfirepro
Can’t believe it’s been nearly 5 weeks since my last update, I'm going to call this update "Find anything to do so I don’t have to get on with the electronics"
Not been a busy time at all, still planning the electronics but not actually doing anything Sad
I've got to start getting on with the tub so finished off the underneath ready to go to the body shop
Two Coats of Lizardskin Sound control...
Two coats of Lizardskin ceramic insulation
And two coats of top coat EM121
Fitted the ride height switches and the electronic park brake switch to the cubby box
Anyone that’s mad enough to have read all this drivel will know that I'm very concerned about the additional heat under the bonnet, so in addition to all the heat limiting under the bonnet I've decided that these don’t look too bad and will help with cooling. I think they will look a lot better when the bonnet is painted black as well.
That’s about it for now, hopefully there will be some electricary progress to report on my next update, thanks for reading
Post #958193 13th Jul 2022 6:58pm
JOW240725
Nice update thanks. Really want to see this up and running!! Thumbs Up Bow down James
Post #958244 14th Jul 2022 4:59am
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
Do you mind me asking where did you get the centre console, I'm nearly at that stage myself Very Happy
I'm loving the colour and wheels Cool
Post #958702 18th Jul 2022 10:18am
Co1
Speed vents look good!
Post #958761 18th Jul 2022 5:11pm
mrfirepro
Thanks fully the electronics are nearly done, and tomorrow is the day when it finally bursts into life.
Having nearly completed this here are some of my notes...
1. I'd planned a new fuse box with 16 ways, which should have left plenty of spares. should have gone for 20 plus...here is a list of things that need power either permanent live or ignition switched (these are in addition to the standard on-air and GM loom fuses, however I have amalgamated some of the spurious fuses into the new fuse board.
a. Engine ECU IGN
b. Start Inhibit ECU IGN
c. Gear Select IGN
d. Air suspension IGN
e. Electronic Park Brake IGN
f. Heated Mirrors IGN
g. Reverse can Relay IGN
h. Park Brake PERM
i. DRL PERM
j. Washer Pump PERM
k. Roof Light bar
l. Dashcams
m.
n.
o.
p. Dashcam battery pack
This is a list of where items are mounted, and they all seem to fit quite well but as expected not much room left.
In the cubby box/gear shifter housing
a. Electronic Park Brake control unit
b. 16-way auxiliary fuse board
c. GM OBD2 port and EML
d. electronic handbrake switch
e. air suspension up/down switches
f. Electronic Park brake control relay
g. Reverse light CAN relay
Under the driver seat - with all the normal LR bits (fuse box, ABS control unit etc etc...)
a. GM ECU
b. GM TCM
c. Speartech Neutral safety switch
d. GM Relays for fuel pump, both fans and something else I've forgotten Embarassed
e. DRL control unit
Under the passenger’s seat (plus AGM battery)
a. On air suspension control ECU
b. On air Air pressure control block
c. On air control relay
d. Dashcam battery pack
Have also directly wired three earth posts to both seat boxes and near the aux fuse board and run additional wires between all three areas and a spare loom to the bulkhead fuse box location, just in case these may be needed in the future.
I'll post some pics up when it's all finished as there is a lot of labelling and tidying up to do.
It however has not been without incidents as the main electronic parking brake controller was wired wrong, the electronic park brake wiring diagram didn’t match the actual unit and shifter interlock is still not working properly (will revisit this when we have the engine running and the gear box can be filled with oil as hopefully it's gearbox related not wiring)
I'll post a first start video over the next few day.
Post #959644 26th Jul 2022 10:22pm
