Home > Technical > Fuel filter housing
mk1collector
Fuel filter housing
Hi, could anyone confirm that all four brass fittings on a 2004 td5 filter housing are part number ESR4724, even the bleed valve fitting?
Ray Thumbs Up Ray
My build thread
Post #857996 25th Sep 2020 12:14am
spudfan
Ireland
Is this the item?
https://www.lrdirect.com/ESR4724-supplied-...TPART.html
https://www.lrdirect.com/ESR4724-3Daptor/?keep_https=yes 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #858253 26th Sep 2020 3:30pm
spudfan
Ireland
https://www.advancedfactors.co.uk/td5-fuel-filter-13790-c.asp 1982 88" 2.25 diesel
Post #858254 26th Sep 2020 3:33pm
mk1collector
I saw that diagram and it’s the wjn500110 at the bottom that threw me. It looks like it says all four fittings are the same but then has a different number for the one with the little filter so I wondered if the different part number was just for the whole assembly including filter and washer? Ray
My build thread
Post #858349 27th Sep 2020 8:18am
spudfan
Ireland
E-mail Advanced Factors and they should be able to clarify things. 1982 88" 2.25 diesel
Post #858374 27th Sep 2020 9:39am
