![]() | Home > Technical > Fuel filter housing |
Hi, could anyone confirm that all four brass fittings on a 2004 td5 filter housing are part number ESR4724, even the bleed valve fitting?
Cheers Ray ![]() My build thread http://www.defender2.net/forum/topic17615.html |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4748 ![]() ![]() |
Is this the item?
https://www.lrdirect.com/ESR4724-supplied-...TPART.html https://www.lrdirect.com/ESR4724-3Daptor/?keep_https=yes 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
https://www.advancedfactors.co.uk/td5-fuel-filter-13790-c.asp 1982 88" 2.25 diesel
I saw that diagram and it’s the wjn500110 at the bottom that threw me. It looks like it says all four fittings are the same but then has a different number for the one with the little filter so I wondered if the different part number was just for the whole assembly including filter and washer? Ray
E-mail Advanced Factors and they should be able to clarify things. 1982 88" 2.25 diesel
