Home > Tdi > Oil in Exhaust Manifold |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2658 |
Paraffin or some kind of solvent-based cleaner will bring it up nicely.
13th Sep 2020 3:28pm |
Fatbaron Member Since: 12 Mar 2016 Location: Devon Posts: 299 |
Cheers Retro, do I need to worry about getting solvent etc. down the intakes?
14th Sep 2020 6:47am |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2947 |
I’ve used meths before it evaporates
14th Sep 2020 8:08am |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
Be worth doing the intercooler too as it will look the same on the inside and degrade its cooling ability.
I generally use Meths too then leave it on a radiator indoors to evaporate off Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
14th Sep 2020 2:06pm |
I’d use a rag for the head ports rather than spraying anything in there.
14th Sep 2020 5:07pm |
I've nicked the old one off my other engine, clean as a whistle. Cleaned out the ports as best I could with a rag dipped in degreaser.
Full size intercooler being put on along with the new turbo, silicone hoses, XL rad etc. I've been stockpiling parts for a year so while the gearbox is out and I've finally got time, I'm chucking it all on. |
14th Sep 2020 6:06pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10810 |
So at last you have a chance to put all of those bits on Red now
Good you have time in between the work load 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
14th Sep 2020 7:52pm |
Yep, cheers Clayton. If you fancy a cuppa mate, feel free to pop round. I can show you what a doddle fitting a slick shift is now the gearbox is out.
15th Sep 2020 3:43am |
Thanks, will come round for a cuppa when i have 5 minutes 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
18th Sep 2020 8:48pm |
