Home > Tdi > Oil in Exhaust Manifold
Fatbaron
I'm finally fitting the new turbo along with a load of other jobs, I've whipped the inlet manifold off which I'll be giving a good clean.
There's obviously now oil in the exhaust manifold too, what would be the best way to get this cleaned out?
The manifold gasket was in 4 pieces when I took it off. Rolling Eyes
Post #855809 13th Sep 2020 1:51pm
Retroanaconda
Paraffin or some kind of solvent-based cleaner will bring it up nicely.
Post #855828 13th Sep 2020 3:28pm
Fatbaron
Cheers Retro, do I need to worry about getting solvent etc. down the intakes?
Post #855911 14th Sep 2020 6:47am
ibexman
I’ve used meths before it evaporates
Post #855927 14th Sep 2020 8:08am
shaggydog
Be worth doing the intercooler too as it will look the same on the inside and degrade its cooling ability.
I generally use Meths too then leave it on a radiator indoors to evaporate off Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #856001 14th Sep 2020 2:06pm
Retroanaconda
I’d use a rag for the head ports rather than spraying anything in there.
Post #856035 14th Sep 2020 5:07pm
Fatbaron
I've nicked the old one off my other engine, clean as a whistle. Cleaned out the ports as best I could with a rag dipped in degreaser.
Full size intercooler being put on along with the new turbo, silicone hoses, XL rad etc. I've been stockpiling parts for a year so while the gearbox is out and I've finally got time, I'm chucking it all on. Cool
Post #856045 14th Sep 2020 6:06pm
L110CDL
So at last you have a chance to put all of those bits on Red now Wink
Good you have time in between the work load Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #856063 14th Sep 2020 7:52pm
Fatbaron
Yep, cheers Clayton. If you fancy a cuppa mate, feel free to pop round. I can show you what a doddle fitting a slick shift is now the gearbox is out. Thumbs Up
Post #856102 15th Sep 2020 3:43am
L110CDL
Thanks, will come round for a cuppa when i have 5 minutes Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #856741 18th Sep 2020 8:48pm
