![]() | Home > Tdi > Oil in Exhaust Manifold |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2706 ![]() ![]() |
Paraffin or some kind of solvent-based cleaner will bring it up nicely.
Fatbaron Member Since: 12 Mar 2016 Location: Devon Posts: 299 ![]() ![]() |
Cheers Retro, do I need to worry about getting solvent etc. down the intakes?
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2957 ![]() ![]() |
I’ve used meths before it evaporates
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
Be worth doing the intercooler too as it will look the same on the inside and degrade its cooling ability.
I generally use Meths too then leave it on a radiator indoors to evaporate off ![]() Self confessed mileage hunter ![]() |
I’d use a rag for the head ports rather than spraying anything in there.
I've nicked the old one off my other engine, clean as a whistle. Cleaned out the ports as best I could with a rag dipped in degreaser.
Full size intercooler being put on along with the new turbo, silicone hoses, XL rad etc. I've been stockpiling parts for a year so while the gearbox is out and I've finally got time, I'm chucking it all on. ![]() |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10891 ![]() ![]() |
So at last you have a chance to put all of those bits on Red now
![]() Good you have time in between the work load ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Yep, cheers Clayton. If you fancy a cuppa mate, feel free to pop round. I can show you what a doddle fitting a slick shift is now the gearbox is out.
Thanks, will come round for a cuppa when i have 5 minutes
