Home > In Car Electronics > Reverse camera locations
excossack
Having just purchased the JVC radio with reversing camera support, and also a reverse camera now is time to mount the camera,
After ideas.
Current ones are;
Mounted onto the number plate light - I have a spacer between the body and the LED unit
Mounted central to the towbar area
Inside rear door
Externally by the rear screen wash
Any I have missed ? General thoughts? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #855470 11th Sep 2020 1:04pm
Ianh
Mine is in the crossmember. In the recess on the right hand side. Keeps it out of harms way, you can’t see it’s there without looking for it, and it gives a good rear view.
Post #855480 11th Sep 2020 1:50pm
markb110
Haven’t got a picture to hand but I removed the rear screen washer then used the hole for the camera wiring, with a grommet for the wiring.
The camera is mounted above the hole, so it is central, I used 3m Very High Bond tape (Amazon) to hold the camera bracket.
I then relocated the screen wash off to one side.
I carry my bike on a carrier and so I wanted It mounted high up so I could see above them.
Hope that helps, I guess the question is not so much the mounting but what is the primary thing that you need to see, ie my reason or some use the camera to line up the tow bar.
Good luck.
Post #855481 11th Sep 2020 1:56pm
excossack
I don't have the hole in the rear xmember due to have a black sheep replacement one. I do have the two holes either side of the tow bar mounts (used for the jack?)
My main one is to be able to see the Harvey Frost trailer when backing it into the drive. I have ordered a 2nd wifi camera that I will mount on the rear of the HF trailer so I can see the cars I am towing.
What the HF looked like.
https://www.defender2.net/forum/topic36874...rvey+frost 1999 Defender TD5 110
Regards
John M0VAZ
Post #855483 11th Sep 2020 2:03pm
ChrisCSL
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Mine was fitted above the back window above the water jet. Gives me a good view behind although I cant see the tow ball because of the spare wheel. I also have parking sensors on my rear NAS step. Both in conjunction work well for me as I often park my 110 in small street spaces.
Chris
Post #855487 11th Sep 2020 2:16pm
markb110
Excossack
Do you have the details of the WiFi camera that you have?
Thanks
Post #855490 11th Sep 2020 2:21pm
Naks
Mine's mounted on the rear work light bracket, the previous one was taped to the rear washer. --
Post #855494 11th Sep 2020 2:58pm
cold
Mine was below the numberplate light but moved it to above the washer, nice and central and less interference from any light sources
Some pics attached
Post #855507 11th Sep 2020 4:29pm
JoolsB
United Kingdom 2011 Defender 90 Puma 2.4 HT Orkney Grey
I’ve got the Optimill one in the number plate light, not the best view but it picks up small children, bollards and other people’s bonnets.
Post #855538 11th Sep 2020 6:51pm
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
I know you already have the camera but I always thought this was a tidy solution from Optimill https://www.optimill-uk.com/number-plate-light-with-camera.html
Post #855539 11th Sep 2020 6:52pm
JoolsB wrote:
...it picks up small children...
I thought that that sort of thing was frowned upon! Rolling with laughter
I have an Optimill number plate light camera, also one on the back of the rack looking downwards, and one on the offside bumperette.
Post #855547 11th Sep 2020 7:32pm
bear100
I have mine fitted on the upper rear Flatdog shelf inside the load space which looks through a tinted rear window, works really well 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #855551 11th Sep 2020 7:58pm
excossack
markb110 wrote:
Excossack
Thanks
This is the one I have ordered. - not arrived yet.
The plan is have a switcher so i can go between two cameras. Mount the camera on the rear of the trailer and take power from the rear of the trailer -either via lighting circuit or i have additional wiring fed from an anderson socket that runs the rear work lights. 1999 Defender TD5 110
Regards
John M0VAZ
Post #855597 12th Sep 2020 7:38am
excossack
This was the other wired camera I bought
https://www.ebay.co.uk/itm/Waterproof-170-...2749.l2649
It does have reverse lines that show up but a quick test and seems OK picture wise. I need to hook up the trailer so i can work out the best position for the camera. 1999 Defender TD5 110
Regards
John M0VAZ
Post #855600 12th Sep 2020 7:40am
excossack
Fitted the camera by mounting it off the rear door high level brake light cover. It took a bit of time playing with locations. Time will tell. 1999 Defender TD5 110
Regards
John M0VAZ
Post #855919 14th Sep 2020 7:32am
