![]() | Home > In Car Electronics > Reverse camera locations |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2280 ![]() ![]() |
Mine is in the crossmember. In the recess on the right hand side. Keeps it out of harms way, you can’t see it’s there without looking for it, and it gives a good rear view.
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2664 ![]() ![]() ![]() |
Haven’t got a picture to hand but I removed the rear screen washer then used the hole for the camera wiring, with a grommet for the wiring.
The camera is mounted above the hole, so it is central, I used 3m Very High Bond tape (Amazon) to hold the camera bracket. I then relocated the screen wash off to one side. I carry my bike on a carrier and so I wanted It mounted high up so I could see above them. Hope that helps, I guess the question is not so much the mounting but what is the primary thing that you need to see, ie my reason or some use the camera to line up the tow bar. Good luck. |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5941 ![]() ![]() ![]() |
I don't have the hole in the rear xmember due to have a black sheep replacement one. I do have the two holes either side of the tow bar mounts (used for the jack?)
My main one is to be able to see the Harvey Frost trailer when backing it into the drive. I have ordered a 2nd wifi camera that I will mount on the rear of the HF trailer so I can see the cars I am towing. What the HF looked like. https://www.defender2.net/forum/topic36874...rvey+frost 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
ChrisCSL Member Since: 10 Aug 2019 Location: Berks Posts: 186 ![]() ![]() ![]() |
Mine was fitted above the back window above the water jet. Gives me a good view behind although I cant see the tow ball because of the spare wheel. I also have parking sensors on my rear NAS step. Both in conjunction work well for me as I often park my 110 in small street spaces.
Chris |
Excossack
Do you have the details of the WiFi camera that you have? Thanks |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2669 ![]() ![]() ![]() |
Mine's mounted on the rear work light bracket, the previous one was taped to the rear washer. --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
cold Member Since: 15 Dec 2018 Location: Yorkshire Posts: 123 ![]() |
Mine was below the numberplate light but moved it to above the washer, nice and central and less interference from any light sources
Some pics attached ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
JoolsB Member Since: 28 Mar 2020 Location: The North Posts: 167 ![]() ![]() ![]() |
I’ve got the Optimill one in the number plate light, not the best view but it picks up small children, bollards and other people’s bonnets.
Scoobeenut Member Since: 04 Mar 2015 Location: West London Posts: 310 ![]() ![]() ![]() |
I know you already have the camera but I always thought this was a tidy solution from Optimill https://www.optimill-uk.com/number-plate-light-with-camera.html
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17729 ![]() ![]() ![]() |
I thought that that sort of thing was frowned upon! ![]() I have an Optimill number plate light camera, also one on the back of the rack looking downwards, and one on the offside bumperette. |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1990 ![]() ![]() ![]() |
I have mine fitted on the upper rear Flatdog shelf inside the load space which looks through a tinted rear window, works really well 2023 Defender L663 V8
2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
This is the one I have ordered. - not arrived yet. The plan is have a switcher so i can go between two cameras. Mount the camera on the rear of the trailer and take power from the rear of the trailer -either via lighting circuit or i have additional wiring fed from an anderson socket that runs the rear work lights. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
This was the other wired camera I bought
https://www.ebay.co.uk/itm/Waterproof-170-...2749.l2649 It does have reverse lines that show up but a quick test and seems OK picture wise. I need to hook up the trailer so i can work out the best position for the camera. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Fitted the camera by mounting it off the rear door high level brake light cover. It took a bit of time playing with locations. Time will tell. 1999 Defender TD5 110
