![]() | Home > Puma (Tdci) > Engine oil change every 6k ? |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8201 ![]() ![]() ![]() |
using branded fitlers Mahle etc would be fine in my experience.
Depending on mileage and how its used you may need to do more frequent changes due to oil dilution from dpf regens. once a year minimum. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 ![]() ![]() ![]() |
As above TBH - any decent branded filter works for me and choose a decent oil. Rgds.
Chris Last edited by Pacha on 11th Sep 2020 3:48pm. Edited 1 time in total |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2667 ![]() ![]() ![]() |
I've been changing the oil every 6 months since I bought mine in 2010, as I don't do much mileage.
An oil change is cheaper than replacing an engine ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2219 ![]() ![]() |
Every 6 months or 5-6k miles, whichever the sooner. Just make sure it’s good low saps oil for the 2.2 . See sticky in tdci section. https://www.defender2.net/forum/topic34176.html Also don’t forget to reset the oil service indicator counter on the ECU. This counter is there to raise a dash message to change the oil due to dpf dilution of the oil. Unless you reset it at oil change it won’t know you have changed oil and will be out of sync with oil changes and will give an inaccurate message
https://www.defender2.net/forum/post440582.html half way down explains the way to do this. I use gen landrover oil filter, they are not expensive and my local dealer always gives me a good discount. Mainly because I always ask for one and get an air filter at the same time. |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 391 ![]() ![]() ![]() |
I have Changed mine every 6000 from new in 2015. Used genuine filters and correct spec oil supplied from Opie 👍
Also changed oils in the axles, gearbox and transfer box every 10000. Coming up to 69000 now. 2015 90 XS Santorini Black |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3704 ![]() ![]() ![]() |
I do the same. Every 6 months I do it and the air filter, then the next 6 months my landy specialist does the full service.
markespark Member Since: 20 Sep 2012 Location: Huntingdon Posts: 85 ![]() ![]() |
Thanks everyone!
I intend to keep this one for a long time !! |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 924 ![]() ![]() ![]() |
That's tomorrows job after work
![]() ![]() Click image to enlarge Genuine filter and Good oil every 6 Thousand K ![]() |
I also use the Millers Oils XF Longlife 5W30 C1 Fully Synthetic Engine Oil as per devon rover’s pic above. Great oil and you can get at a reasonable price on line.
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 570 ![]() ![]() ![]() |
1...2 yrs
6...12 K miles 100 K miles on the counter - but mine's no commuter. No short distance trips. No excessive use, while engine is cold. That's important. For any modern Diesel engine with EGR + DPF + big volume of motor oil Besides, I assume things to be a bit overestimated. Transit engines are work horses... ![]() https://haynes.com/en-gb/tips-tutorials/fo...dels[/img] |
