Home > Puma (Tdci) > Engine oil change every 6k ?
markespark
2016 Defender 110 Puma 2.2 USW Indus Silver
Hi all new to tdci ownership
Been advised to best look after my 2.2 to change the oil every 6000 miles & only use genuine Lr oil filter
Good advice ?
Post #855436 11th Sep 2020 9:09am
jst
using branded fitlers Mahle etc would be fine in my experience.
Depending on mileage and how its used you may need to do more frequent changes due to oil dilution from dpf regens.
once a year minimum. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #855441 11th Sep 2020 10:15am
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
As above TBH - any decent branded filter works for me and choose a decent oil. Rgds.
Chris
Post #855444 11th Sep 2020 10:50am
Naks
I've been changing the oil every 6 months since I bought mine in 2010, as I don't do much mileage.
An oil change is cheaper than replacing an engine Thumbs Up --
Post #855449 11th Sep 2020 11:23am
Ianh
Every 6 months or 5-6k miles, whichever the sooner. Just make sure it’s good low saps oil for the 2.2 . See sticky in tdci section. https://www.defender2.net/forum/topic34176.html Also don’t forget to reset the oil service indicator counter on the ECU. This counter is there to raise a dash message to change the oil due to dpf dilution of the oil. Unless you reset it at oil change it won’t know you have changed oil and will be out of sync with oil changes and will give an inaccurate message
https://www.defender2.net/forum/post440582.html half way down explains the way to do this.
I use gen landrover oil filter, they are not expensive and my local dealer always gives me a good discount. Mainly because I always ask for one and get an air filter at the same time.
Post #855454 11th Sep 2020 12:24pm
Vitesse
I have Changed mine every 6000 from new in 2015. Used genuine filters and correct spec oil supplied from Opie 👍
Also changed oils in the axles, gearbox and transfer box every 10000. Coming up to 69000 now. 2015 90 XS Santorini Black
Post #855462 11th Sep 2020 1:07pm
Co1
I do the same. Every 6 months I do it and the air filter, then the next 6 months my landy specialist does the full service.
Post #855476 11th Sep 2020 2:36pm
markespark
Thanks everyone!
I intend to keep this one for a long time !!
Post #855479 11th Sep 2020 2:50pm
Devon-Rover
That's tomorrows job after work Thumbs Up
Genuine filter and Good oil every 6 Thousand K Cool Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #855517 11th Sep 2020 6:25pm
Ianh
I also use the Millers Oils XF Longlife 5W30 C1 Fully Synthetic Engine Oil as per devon rover’s pic above. Great oil and you can get at a reasonable price on line.
Post #855524 11th Sep 2020 7:00pm
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
1...2 yrs
6...12 K miles
100 K miles on the counter - but mine's no commuter. No short distance trips. No excessive use, while engine is cold.
That's important. For any modern Diesel engine with EGR + DPF + big volume of motor oil
Besides, I assume things to be a bit overestimated. Transit engines are work horses...
https://haynes.com/en-gb/tips-tutorials/fo...dels[/img]
Post #855562 11th Sep 2020 9:32pm
