Home > Technical > Non starting possible fuel issue |
llessur Member Since: 15 Nov 2011 Location: Hereford Posts: 151 |
So in addition I have now changed the fuel filter, checked the relays under the seat are all pushed in firm. The orange engine management light is illuminated so I presume there is power to the ECU. I now have clean fuel with no bubbles present in the clear plastic pipe I have added to the blue fuel line connector going to the pump, but no smoke on cranking the engine from the exhaust. Now my only thought is whether the VCV I replaced is faulty (£30 new off ebay) and I need to buy a Denso or Genuine LR (twice the price but maybe you really do get what you pay for)
Can I slacken a connector on the fuel rail to check the VCV is working ? |
10th Sep 2020 5:08pm |
Can you hear the fuel pump prime when switching the ignition to position 1? Ray
10th Sep 2020 6:24pm |
No noise in position 1 but I have never heard one previously. Forgive me but I thought the Fuel pump was just the mechanical on the engine with no electric pump in the tank (2.4 TDCi)
Does anyone know what the green connector ( not the VCV connector ) on the Fuel pump does and if I can test it ? |
10th Sep 2020 7:19pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10801 |
This maybe a outside of the box thought, but could it be the immobiliser, if you have an alarm fitted ? 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
10th Sep 2020 8:01pm |
OK so the Green connector is temperature sensor - I will rule that out then.
10th Sep 2020 8:02pm |
Thanks
I will try an immobiliser bypass , at this stage I will try anything, but I thought the immobiliser would stop the engine cranking. |
10th Sep 2020 8:05pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5731 |
I didn’t think the 2.4 had a tank pump, so had to have a special tool to bleed fuel ?
Does the 2.4 have a crash sensor for the fuel system. |
10th Sep 2020 8:16pm |
I'm no expert, but i think from memory that a mate on a Td5 i think had this, it would crank, but not let it start 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
10th Sep 2020 8:20pm |
If it is the immobiliser then the light in the instrument cluster would normally inform you
What is immobiliser light doing? |
10th Sep 2020 9:24pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17457 |
No pump in tank, no inertia switch on a.2.4 |
10th Sep 2020 9:30pm |
That’s what I thought. So the OP will need to get priming device to bring fuel up to the engine.
10th Sep 2020 9:32pm |
Blowing hard into (or connecting an airline to) the tank breather works just as well.
10th Sep 2020 9:40pm |
is where not crash sensor built in to 10 AS for 2.4 engine |
11th Sep 2020 7:34am |
So this morning I applied the bridge to the IPAC - no change
Swopped IPAC with another 2.4 - no change. No immobiliser light on and 10AS locking working as usual by the way. I also went around the earth connections and added a couple for good measure. Going to swop 10AS and Engine ECU from another 2.4 tonight, just to rule those out. I also inspected the engine wiring harness and could not see anything but considering swopping that at the weekend, if no success before. I know I have fuel to the low LP side of the pump, so in my mind as I am not getting any smoke out the exhaust on cranking, it could be the LP / HP pump, pressure in the fuel rail or triggering of the injectors, but please if you can think of anything else, shout up. Still wondering if I replaced a failed VCV with a duffer that does not work also, so if my skinless hands recover a bit I might try taking the VCV of the running Defender and try it on this, but its a real pain with fat arthritic hands. |
11th Sep 2020 9:46am |
