Home > Td5 > difficult starting. I am confused.
Page 1 of 3 123>
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
My 2003 90 td5 suddenly starts difficult sometimes.
The full story, Some parts may or may not be applicable.
Setup:
I have 2 batteries a big one from a D3 and an old style optima red Top. Connected together with a relay that is operated by a voltage sensing piece of electronics.
The Big battery is connected with the Alternator, starting motor and the winch, the rest off the car is connected to the Optima.
The relais will close when the big battery get a voltage above 13V and will disconnect below 11V. SO while winching the Optima will supply the car and the engine will not stop because the ECU will have a too low voltage.
Symptoms:
We were on holiday and the day before we left I fuelled up in Germany and after a long night off heavy rain we decided that we would go home so I tried starting my 90 td5 and it didn't really want to start. It lloked like the glow system didn't work. After some tries I got it running, first seconds it run a little rough but after it was good. Loaded all camping gear and it started again, not easy but it started.
Normally it starts directly
Drove home 400 km without taking the risk off stopping. Very Happy next day it started almost as normal and I fuelled up where I normally fill-up. A few days later I went to my mother 175km one way. It had some difficulty starting in the morning but after that no problem.
Last Thursday I put my 90 inside as I changed my rear diff. (my Detroit locker started misbehaving a little so I put a normal on in) After that a short test drive. no problem. Starting like normal.
In the evening I wanted to go I didn't want to start. I had to get my wifes car to go.
What I noticed:
It looks like the glow system doesn't work.
However mesuring voltages on both sides off the glow relais I see the relais works and noticed that power goes to the glow plugs while waiting on the glowlight to go off and when I try to start the power to the glow plugs is cut and directly after I release the ignition key the power comes back for a short while.
Is this normal behavior??
my old style nanocom gave the following error codes:
10-08 glowplug relay
19-07 noisy crank signal
After clearing them once they didn't come back even after more failed starts.
I checked an old glow plug that gives me 0.4 Ohm resistance the 4 glowplugs in the 5 cylinder engine that I could find Laughing all gave 0.7 Ohm. So no open circuit so I think they are still OK. These were replaced a few years ago.
With the Nanocom I can send power to the glowplugs but very short. Too short for my voltmeter to give a real voltage but I can see something is coming. On the relais side I get around 11 V.
While starting I get about 250 rpm on my Nanocom. It sounds like how it did before.
I checked the cranck sensor plug and it looked good. My 90 had some swimming lessons and because off that and some damage it was a write off. So I always first check connectors.
When it runs the idle rpm according to Nanocom is fluctuating only 5 rpm so I think that is OK
I changed the battery seperation wiring so the batteries will be connected directely when the ignition is on. It looks like it helps a little but not completely. However I need to do a cold check in the morning to know more
So what can it be?
It looks like the glowing system is not working however I can't find a fault.
The crank signal cannot be that bad as when it starts it runs fine.
Could it be bad fuel? I used almost all the "bad"fuel driving home and I have filled up twice after that.
It starts sometimes like normal and sometimes very difficult.
So I don't know on the moment.
. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #854591 6th Sep 2020 6:33pm
jst
glow plugs or not it will still eventually start. Just more cracking when cold.
Sounds more like a fuel issue to me.
Any different to the way its parked.. nose up or down. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #854600 6th Sep 2020 7:06pm
roel
Old picture but there is no real up or down.
There is a lot off smoke when it starts after difficult starting. Roel
Post #854603 6th Sep 2020 7:28pm
jst
Lots of smoke says not fuel then. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #854605 6th Sep 2020 7:43pm
roel
Is not glowing while cranking normal? To reduce battery load maybe? Roel
Post #854608 6th Sep 2020 7:56pm
landy andy
Assume there is no noise from the fuel system when trying to start? Have you tried using the fuel priming procedure before starting? Thinking could be the injector washers.
Another thought is that sometimes the starter motor can cause electrical feedback (not the correct term) that stops the ecu from sending the correct messages to the engine. I’m sure an adult can explain that better.
Only other easy things are clean crank sensor, and fit new fuel filter.
Post #854630 6th Sep 2020 9:42pm
4RF RDS
Suggest fuel filter change first before anything else. Sounds like a fuelling issue from what you describe. Perhaps injector seals? Have you plugged it in to see if any codes are up? 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #854641 7th Sep 2020 3:26am
I can't remember for sure how the Td5 starting protocol works, but I presume that there must be a camshaft position sensor (in addition to the crankshaft position sensor) to let the ECU determine if the engine is on the compression or exhaust stroke when the crankshaft sensor indicates TDC. Usually the camshaft sensor is only referenced during start-up, since once the engine is running it knows which of the two pulses per cycle from the crankshaft sensor is which, so no longer needs further referencing. Is it possible that your camshaft sensor or the associated connector is faulty?
roel wrote:
... while winching the Optima will supply the car and the engine will not stop because the ECU will have a too low voltage.
Some time ago I was having the usual Td5 alternator issues on my Disco2, and during the course of a journey the alternator failed completely resulting in me driving home on battery power alone. I happened to have a Nanocom connected at the time, so (until it shut down) was able to see what was happening at different voltages as the vehicle progressively died. I can't remember the crucial voltages any more (I did write it up somewhere on the forum) but it was interesting that the ECU was the last to go, and the engine kept running long after I thought it would have cut out - progressively the radio, the wipers, the indicators, the instrument pack, the Nanocom, just about everything stopped working, but the motor kept running. It was very strange driving what was effectively an electrically-dead vehicle but with the fuel pump and injectors still working. I can only assume that in those days LR engineers still put a lot of thought into how the vehicle should behave under extreme failure conditions.
I wonder what the 2020 Def would do without an alternator....
Post #854665 7th Sep 2020 9:36am
4RF RDS
That is good info to know! Thanks for sharing Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #854679 7th Sep 2020 10:23am
MadTom
TD5 has not any cam shaft sensor, only on crank shaft sensor. And TD5 ECU has 2 supply voltage dependent work states - it can work with very low voltage compared to standard 12V, this is mainly for engine starting.
TD5 engine was gesigned for use on offroad car, not modiffied for it. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #854698 7th Sep 2020 12:21pm
jst
I still believe its fueling related not electical, supply seems OK if you get clouds of smoke on start up so looking like timing or fuel arriving at wrong time, or inconsistent fuel supply, cracked filter head, pump problems, regulator issue? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #854708 7th Sep 2020 1:34pm
roel
@ Blackwolf, I had an altenator failing while playing off-road for a long weekend. Off-course it failed the first day. I was charging during the night and while we were having lunch. On the last day I quit a liitle early to go charging for my 200 km drive home with a trailer with the lightweight from on off my friends.
I almost made it, and after your story I made have made it. But about 30 km from home I lost my rev counter, that was the first thing that stopped working. We stopped at the first fuel station. We took a battery from one off the other 4x4's on one off the traillers and connected that battery with jumper cables to my batteries. Obiously it wouldn't crank on it's own so one off friends put his car and trailler in front of my 90 with trailler and pulled me to start my engine.
It was fun and the most funny thing was the looks off other people at the petrol station.
Different time but same group. Not all on the picture.
@ jst. It might be a fuel problem. Priming might have helped to start this morning. It was not perfect but started better then on very bad moments. Once it started the first time all other tries today were perfect starts without priming. So more test to do. It was warmer this morning then the days before.
Question about primiing: I know the procedure, put it on ignition and pump the throttle a few times and then the engine light starts blinking.
I normally after changing the fuel filter prime it and when the pump shuts down I start the engine. But this time as I was measuring voltages I was a little late and noticed that the pump runs for about a minute and then shuts down for about 10 seconds and runs for a minute again. Is this a normal procedure?
What is the difference from just switching on ignition as the pumps runs also for about a minute and then shuts down.
My fuel pump was changed last year on my way on holiday so I expect and hope that the pump will not be the problem.
I changed my regulator in 2010 when it was leaking, It's not leaking now. Roel
Post #854763 7th Sep 2020 5:23pm
benniferj
If I were you I'd put the winch on a separate battery and the rest of the car on the main one. Is there a chance that your ECU is on the Optima which is running flat for some reason (you said its an old one!)
Ive never known of anyone to split the starter motor and alt feeds away from the rest of the vehicle... normally its accessories on batt2 Insta: @thebenjordan4x4
Post #854796 7th Sep 2020 7:02pm
roel
But you are not me. Very Happy I don't do what everybody else does because everybody else does that. I do most things for a reason (as explained) and some for fun.
My first Idea was indeed that my Optima was bad so I changed the programming off the electronics so now the batteries directly connect together when the ignition is on.
And I don't see your point of having the starter motor on the same battery as the rest of the car? What is the benefit of that if you have 2 good batteries?
Currently I am convinced the batteries are not my starting problem. Roel
Post #854829 7th Sep 2020 8:41pm
jst
when priming it runs for a lot longer than a minute. if you pull the pump could just be muck in the tank filter?
i dont think its electirical Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #854838 7th Sep 2020 8:59pm
Page 1 of 3 123>
