Home > Td5 > difficult starting. I am confused.
Page 2 of 3 <123>
MadTom
During the priming procedure the rest is switched off - like glow plugs, to save battery power, and it cycles much longer compared to one cycle after switching on the ignition.
Another possible problem is only partly working fuel pump, not delivering enough pressure for quick purge of fuel system on start, possibly with some small fuel leak somewhere. TD5 with fully primed fuel system runs also without the fuel pump, but with much lower power, with only partly working pump, the power has only reduced a bit (Discovery 2 top speed dropped from 160 km/h to 140). "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #854865 8th Sep 2020 5:39am
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
I also don't think it is electrical. Probably fuel related as I can't find a fault in my glow system.
On this moment I don't suspect the pump. It's only one year old and when my 90 runs it is as powerful as before.
So I am thinking in the direction off not enough fuel at start-up.
Does the fuel regulator have a part in this?
Or could it be the non return valve near the fuel filter? Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #854898 8th Sep 2020 8:17am
jst
regulator offers high and low pressure feeds. low pressure unlikely to affect the starting. air in system or fuel blockage more likely. filter head NRV, cracked filter head allowing air in (any hissing?) blocked filter where feed enters rear of engine? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #854907 8th Sep 2020 9:19am
dorsetsmith
Does the fuel regulator have a part in this? fuel regulator shod only let by that over 4 bar returning fuel to tank
or air bleed in filter head
Post #854908 8th Sep 2020 9:20am
roel
Yesterday I changed the fuel filter and the small connector to the starter motor.
Both I think would not have influences on my starting problems as I would expect that the fuel filter would also give problems while driving and asking a lot off fuel while flooring it. But that was not the case.
The connector off the starter motor I don't think makes a difference as if it would start dificult it also was running rough for a short time after starting. I changed the plug and rerooted the cable a little to give it some slack as it was tight and fell off a few times.
However this morning it started as it should if it have been driven 5 minutes ago.
Or was it the filter and as the fuel warms up very quickly it warmed up the filter and that helped the fuel coming through the filter?
I am still confused and I don't believe that this was the solution but we will see.I might know more tomorrow morning. Very Happy Roel
Post #855092 9th Sep 2020 7:52am
MadTom
Possible filter or some air in fuel system. From my experience, TD5 needs more than one fuel system purge - first after new filter instalation with proper purge cycle and short engine run, second next day with only normal start - this takes out the rest of air with some short bubling noise from fuel system. After this, all bubling noises are gone. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #855108 9th Sep 2020 8:15am
roel
New update. I started fine this morning but after a short drive (5 km) and 1/2 hour wait he took a little longer to start. (coolant temp 46 C) Back home after half an hour same story not directly starting. However after starting and switching off it will start without any problems.
A few hours later also starting without any problems. Roel
Post #855362 10th Sep 2020 6:10pm
gilarion
Re: difficult starting. I am confused.
roel wrote:
Symptoms:
We were on holiday and the day before we left I fuelled up in Germany
If everything is fine now and it seems that by your last post things are getting better, perhaps it was just down to poor or dirty fuel, which may be when you fueled up is that when the problems started. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #855393 10th Sep 2020 9:12pm
roel
It is getting better, surely after changing the fuel filter. So it looks like it had to do with the bad German diesel.
I know German fuels are bad as my Disco 3 V8 also needed a lot more fuel per km in Germany then in The Netherlands. Whistle
However my 90 might not be perfect but it was always a perfect starter (if I had enough power in the batteries) and now it was/is not.
I filled up twice already. Most German fuel was used to drive home 400 km so there wasn't that much left in the tank as I didn't want to take the risk to stop.
I filled up twice with Dutch fuel already and drove roughly 700 km so the second tank off dutch fuel is down to 1/4 now.
It looks like it now only has some problems starting when warm and left for a short while. I don't understand that on the moment.
But yes I hope it was just the fuel and I might buy some injector cleaner if that might help. Any thoughts about that? Roel
Post #855423 11th Sep 2020 7:21am
Lwb97
Wales 2002 Defender 90 Td5 HT Oslo Blue
If your problem persists I’d be doing the injector seals, especially if it’ll start straight up when your just checking to see if it’ll start. Sounds like one of the o rings aren’t sealing and allowing air into the system hence the poor starting after a journey.
Post #855437 11th Sep 2020 8:13am
roel
Today he told me that he doesn't like it anymore.
After a good start in the morning it stalled while waiting at a trafic light after 4 km driving. It started difficult again so I continued but after another 4-5 km it died while driving about 100 km/hr. I got it starting again. Waiting a short time and then priming and then it would start after a few tries but difficult I had to keep starting till it really would run on it's own.
So I decided to drive back home. It died another 3 times before I came home.
So clearly there is something wrong and I doubt it was the German fuel.
Once it starts it runs fine, no power loss AFAIK till it dies suddenly. It can die on decent throttle but also when reducing speed before a roundabout.
So what can it be?
Small filter at the fuel pressure regulator?
injector seals?
Or something completely different? Roel
Post #855798 13th Sep 2020 12:48pm
Adammacky
I had very similar symptoms when my crankshaft position sensor was playing up, the wires into the harness were perished so replaced the harness and sensor, sorry if this is no help and good luck Thumbs Up
Post #855821 13th Sep 2020 2:59pm
mk1collector
When my injector seals went I had the driving for a while then dying and hard to restart symptoms. Ray
My build thread
Post #855849 13th Sep 2020 4:47pm
roel
I will order the injector seals etc. tomorrow.
I don't think it is the crackshaft position sensor The way it dies and how it starts again. That's why I think it is fuel related and not a sensor. Roel
Post #855856 13th Sep 2020 5:28pm
roel
Last update I hope. Twisted Evil
I changed the injector seals and copper burn plates.
The short test drives from yesterday and today went fine. Started directly cold and warm. This morning I tried without glowing and it started within a second.
We will see what a longer drive will do. Very Happy Roel
Post #856928 19th Sep 2020 5:05pm
Page 2 of 3 <123>
