Home > Td5 > difficult starting. I am confused. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8136 |
glow plugs or not it will still eventually start. Just more cracking when cold.
Sounds more like a fuel issue to me. Any different to the way its parked.. nose up or down. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
6th Sep 2020 7:06pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Old picture but there is no real up or down.
Click image to enlarge There is a lot off smoke when it starts after difficult starting. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
6th Sep 2020 7:28pm |
Lots of smoke says not fuel then. Cheers
6th Sep 2020 7:43pm |
Is not glowing while cranking normal? To reduce battery load maybe? Roel
6th Sep 2020 7:56pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5769 |
Assume there is no noise from the fuel system when trying to start? Have you tried using the fuel priming procedure before starting? Thinking could be the injector washers.
Another thought is that sometimes the starter motor can cause electrical feedback (not the correct term) that stops the ecu from sending the correct messages to the engine. I’m sure an adult can explain that better. Only other easy things are clean crank sensor, and fit new fuel filter. |
6th Sep 2020 9:42pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 952 |
Suggest fuel filter change first before anything else. Sounds like a fuelling issue from what you describe. Perhaps injector seals? Have you plugged it in to see if any codes are up? 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
7th Sep 2020 3:26am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17516 |
I can't remember for sure how the Td5 starting protocol works, but I presume that there must be a camshaft position sensor (in addition to the crankshaft position sensor) to let the ECU determine if the engine is on the compression or exhaust stroke when the crankshaft sensor indicates TDC. Usually the camshaft sensor is only referenced during start-up, since once the engine is running it knows which of the two pulses per cycle from the crankshaft sensor is which, so no longer needs further referencing. Is it possible that your camshaft sensor or the associated connector is faulty?
Some time ago I was having the usual Td5 alternator issues on my Disco2, and during the course of a journey the alternator failed completely resulting in me driving home on battery power alone. I happened to have a Nanocom connected at the time, so (until it shut down) was able to see what was happening at different voltages as the vehicle progressively died. I can't remember the crucial voltages any more (I did write it up somewhere on the forum) but it was interesting that the ECU was the last to go, and the engine kept running long after I thought it would have cut out - progressively the radio, the wipers, the indicators, the instrument pack, the Nanocom, just about everything stopped working, but the motor kept running. It was very strange driving what was effectively an electrically-dead vehicle but with the fuel pump and injectors still working. I can only assume that in those days LR engineers still put a lot of thought into how the vehicle should behave under extreme failure conditions. I wonder what the 2020 Def would do without an alternator.... |
7th Sep 2020 9:36am |
That is good info to know! Thanks for sharing 2010 Range Rover MkIII Autobiography Super Charged (Idris)
7th Sep 2020 10:23am |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 635 |
TD5 has not any cam shaft sensor, only on crank shaft sensor. And TD5 ECU has 2 supply voltage dependent work states - it can work with very low voltage compared to standard 12V, this is mainly for engine starting.
TD5 engine was gesigned for use on offroad car, not modiffied for it. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo |
7th Sep 2020 12:21pm |
I still believe its fueling related not electical, supply seems OK if you get clouds of smoke on start up so looking like timing or fuel arriving at wrong time, or inconsistent fuel supply, cracked filter head, pump problems, regulator issue? Cheers
7th Sep 2020 1:34pm |
@ Blackwolf, I had an altenator failing while playing off-road for a long weekend. Off-course it failed the first day. I was charging during the night and while we were having lunch. On the last day I quit a liitle early to go charging for my 200 km drive home with a trailer with the lightweight from on off my friends.
I almost made it, and after your story I made have made it. But about 30 km from home I lost my rev counter, that was the first thing that stopped working. We stopped at the first fuel station. We took a battery from one off the other 4x4's on one off the traillers and connected that battery with jumper cables to my batteries. Obiously it wouldn't crank on it's own so one off friends put his car and trailler in front of my 90 with trailler and pulled me to start my engine. It was fun and the most funny thing was the looks off other people at the petrol station. Click image to enlarge Different time but same group. Not all on the picture. @ jst. It might be a fuel problem. Priming might have helped to start this morning. It was not perfect but started better then on very bad moments. Once it started the first time all other tries today were perfect starts without priming. So more test to do. It was warmer this morning then the days before. Question about primiing: I know the procedure, put it on ignition and pump the throttle a few times and then the engine light starts blinking. I normally after changing the fuel filter prime it and when the pump shuts down I start the engine. But this time as I was measuring voltages I was a little late and noticed that the pump runs for about a minute and then shuts down for about 10 seconds and runs for a minute again. Is this a normal procedure? What is the difference from just switching on ignition as the pumps runs also for about a minute and then shuts down. My fuel pump was changed last year on my way on holiday so I expect and hope that the pump will not be the problem. I changed my regulator in 2010 when it was leaking, It's not leaking now. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
7th Sep 2020 5:23pm |
benniferj Member Since: 20 Oct 2016 Location: Basingstoke Posts: 361 |
If I were you I'd put the winch on a separate battery and the rest of the car on the main one. Is there a chance that your ECU is on the Optima which is running flat for some reason (you said its an old one!)
Ive never known of anyone to split the starter motor and alt feeds away from the rest of the vehicle... normally its accessories on batt2 Insta: @thebenjordan4x4 |
7th Sep 2020 7:02pm |
But you are not me. I don't do what everybody else does because everybody else does that. I do most things for a reason (as explained) and some for fun.
My first Idea was indeed that my Optima was bad so I changed the programming off the electronics so now the batteries directly connect together when the ignition is on. And I don't see your point of having the starter motor on the same battery as the rest of the car? What is the benefit of that if you have 2 good batteries? Currently I am convinced the batteries are not my starting problem. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
7th Sep 2020 8:41pm |
when priming it runs for a lot longer than a minute. if you pull the pump could just be muck in the tank filter?
i dont think its electirical Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
7th Sep 2020 8:59pm |
