Home > Maintenance & Modifications > Help needed - plywood base for Landrover OEM Expedition rack
Markez79
Hi,
Does anyone know if the Safety Devices plywood base works on the Land Rover Expedition rack? If not, does anyone know of anyone else who makes these?
Thanks
Mark
Post #852382 27th Aug 2020 1:57pm
trooper
United Kingdom 2002 Defender 90 Td5 HT Tamar Blue
I would also like to know this. Or a possible alternative.
Peter
Post #852413 27th Aug 2020 4:19pm
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
I know it's not plywood but have you guys seen this....
https://www.defender2.net/forum/topic20766...cken+floor
Post #852427 27th Aug 2020 5:09pm
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
You could use trailer flooring. Something like this: https://www.hm-wood-shop.co.uk/shop/trailer-flooring-1363c1.html
Or just buy some ply and paint with Tekton or similar. WARNING.
This post may contain sarcasm.
Post #852438 27th Aug 2020 5:53pm
Ianh
Another potential option
I would think the 12mm stokbord would do the trick.. if not the 18mm would.
I was thinking of the 18mm as a replacement trailer floor. If its completely rot proof and can stand a cow bashing or chewing it then it’s going to be tough and last.
https://www.solwayrecycling.co.uk/shop/farmers/stokbord
Just need a good price for delivery of a single sheet.
Post #852451 27th Aug 2020 6:32pm
Zed
I've only seen stockboard whilst shopping at Mole Valley so I'm no expert but i think you would have to check the thickness in person. The thick stuff is pretty heavy and the thin may be too bendy. WARNING.
Post #852453 27th Aug 2020 7:02pm
sako243
Surely it's just Buffalo board with a big markup? Laughing
Buy some sheets, jigsaw and paint the edges and away you go. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #852456 27th Aug 2020 7:09pm
DOOFER
I used trailer floorboarding. Worked really well but then I did get it cheap through work DON'T PANIC
Post #852706 28th Aug 2020 6:09pm
