Home > Maintenance & Modifications > Help needed - plywood base for Landrover OEM Expedition rack |
trooper Member Since: 11 Mar 2014 Location: west sussex Posts: 102 |
I would also like to know this. Or a possible alternative.
Peter |
27th Aug 2020 4:19pm |
rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 937 |
I know it's not plywood but have you guys seen this....
https://www.defender2.net/forum/topic20766...cken+floor |
27th Aug 2020 5:09pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3324 |
You could use trailer flooring. Something like this: https://www.hm-wood-shop.co.uk/shop/trailer-flooring-1363c1.html
Or just buy some ply and paint with Tekton or similar. WARNING. This post may contain sarcasm. |
27th Aug 2020 5:53pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2048 |
Another potential option
I would think the 12mm stokbord would do the trick.. if not the 18mm would. I was thinking of the 18mm as a replacement trailer floor. If its completely rot proof and can stand a cow bashing or chewing it then it’s going to be tough and last. https://www.solwayrecycling.co.uk/shop/farmers/stokbord Just need a good price for delivery of a single sheet. |
27th Aug 2020 6:32pm |
I've only seen stockboard whilst shopping at Mole Valley so I'm no expert but i think you would have to check the thickness in person. The thick stuff is pretty heavy and the thin may be too bendy. WARNING.
27th Aug 2020 7:02pm |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1225 |
Surely it's just Buffalo board with a big markup?
Buy some sheets, jigsaw and paint the edges and away you go. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
27th Aug 2020 7:09pm |
DOOFER Member Since: 07 Oct 2012 Location: Suffolk Posts: 412 |
I used trailer floorboarding. Worked really well but then I did get it cheap through work DON'T PANIC
28th Aug 2020 6:09pm |
