![]() | Home > Maintenance & Modifications > Paint Recommendations for New Galvanised Chassis |
Morning All,
About to purchase a new galv chassis for my pending rebuild. As i am not a fan of the bare galv chassis look, I would like to paint it satin black. Looking for recommendations for paints please. I have some Mordent Solution already so was planning on a red oxide prime and satin black top coat. I will probably also use Dinitrol cavity wax internally for good measure. I was planning on using the Buzzweld Galv-in-One paint but after very poor experience with their RCP and CIO on another chassis I am slightly put off using their products. Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
I think I'd go for an etch primer rather that red oxide and POR-15 makes a good chassis paint.
For the obviously visible rear crossmember, I've found that a few spray coats of a decent satin black finished with a clear lacquer gives a nice result. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Cheers, POR15 was on my list but I believe it is only available as a gloss finish?
I was also looking at Coroless paints but seem to be aimed more at overpainting corrosion 02' 110 TD5 Double Cab Rebuild Thread |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1108 ![]() ![]() ![]() |
While you're at it have a look at what this couple did to their new galvd frame
![]() https://youtu.be/DyBbXmVFZUo?t=151 |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2216 ![]() ![]() |
From what I’ve read buzzweld use a modified corroless paint.
If interested in neat corroless then the best option after etching the galvanised chassis is their S primer followed by their RF16 topcoat. They also do an etch primer for galvanised metal. https://www.arc-rite.co.uk/paints/automoti...t-products Worth giving them a call and they can advise. I’ve used corroless chassis in one on another vehicles sills and it worked well. Some more alternatives are available from frosts. They have Eastwood, frost and por15. Again worth giving them a call to get their views. [url]https://www.frost.co.uk/chassis-paints/[url] Bilt hamber as stated above have a good range as well. https://www.bilthamber.com/ |
SteveT247 Member Since: 21 Feb 2011 Location: Central Posts: 491 ![]() ![]() ![]() |
I used Galv in one on my rear X member back in feb, no complaints so far. I can't remember if I T washed it (they say you don't need to but can't see it doing any harm if you do), or just used degreaser prior to painting.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 867 ![]() ![]() ![]() |
Have a look at my 127 thread for a rundown of the paint I used, can thoroughly recomend Jotun products. 1985 127 V8 Build Thread
Series 2 109" Series 1 80" |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 ![]() ![]() ![]() |
I went with the Corroless approach after speaking to Arc-rite. They have a paint which is supposed to be suitable to go directly on galvanized metal, no etch primer needed. However in the few places where I've caught it with a spanner, it seems to have chipped off pretty easily, so the jury is out for me. 2005 Td5 90 XS
1989 V8 110 CSW |
That is interesting as I spoke with Arc-Rite today and they told me that I must use an etch prime first! Then recommended the corroless glass flake chassis paint over that. 02' 110 TD5 Double Cab Rebuild Thread
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 765 ![]() ![]() |
Did my new Richards chassis a few months ago, leaving it bare was never an option (I love bare galvanising on a LR but NOT the chassis). Carried out lots of research beforehand and decided on the following process.
Chassis clean and de-grease. T-Wash. Arc-Rite Etch Primer, brush for main chassis rails / crossmembers and spray for awkward to reach areas. Frosts Extreme Chassis Black (Satin), once again brush for main chassis rails and spray for awkward to reach areas and rear crossmember (the most visible spot). As it happens it brushes so smoothly that you can hardly tell the difference between the brushed & sprayed areas. Black Waxoyl chassis black sprayed over the whole chassis apart from the visible face of the rear crossmember. Looks great and hasn't shown any signs of falling off just yet! As above, I will probably use clear Waxoyl internally at some point which is probably overkill but A- I like the product and have been using it for years, B- I have plenty and C- I have the equipment to spray the internal sections. By the way, before anyone comments about the overspray on the wall let me say that it isn't! ![]() Parking in exactly the same spot for 21-years has left soot marks that don't wash away. ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ONE LIFE, GET IT! |
Disneysland Member Since: 25 Apr 2024 Location: Yorkshire Posts: 6 ![]() ![]() ![]() |
I just watched a YouTube video where a chap in America spent 9 months doing every test imaginable on about 10 chassis paints. The POR-15 was one of the worst. The best was mastercoat primer with either mastercoat top coat or raptor bedliner depending on the finish you want. They performed massively better than the rest.
Unfortunately mastercoat seem to be American and I would prefer a smooth finish. Some of the best restomod companies use raptor or Kent graphene primer and stone chip top coat. I’m still researching what’s best for a new finish to a galv chassis? T wash / Mordent seems the confirmed best first step. ?si=yoJ7x2rsRuATrRO1 |
Belgian Deffie Member Since: 27 May 2023 Location: Ghent, Belgium Posts: 6 ![]() ![]() ![]() |
Gentlemen,
Honestly, from a guy owning a company specialised in protective and marine coatings, think about applying a 2 component epoxy (look into Sigmashield 880). If it can withstand submersive (under water) conditions, it surely can protect your chassis. I am looking into doing this on mine as well. Available in 20 litres and 4 litre packaging, grey and black. Top product. |
MarkBrown Member Since: 03 Oct 2022 Location: Mid Wales Posts: 530 ![]() ![]() ![]() |
I did mine in chassis black, then dinitrol. 1983 110 automatic OM606
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Yes my galvanisers sells a product for it called GALVACOAT, sounds a lot like what you’re recommending. |
