Home > Technical > Failed two pin diff in 65plate 110!!
Oldowner
Just looked at a friend of mines one owner very late 65plate 110USW with massive amounts of slop in the front axle. The front diff has let go and looking through the oil filler, it’s the useless two pin junk, not surprised it has let go. I thought these two pin units had been banished from the front of the 110 in 2011 and replaced with the HD four pin, so what’s it doing here?! Last few months of production cost cutting exercise? Use up anything we have left?
Interestingly it has the very late HD one piece rear half shafts fitted from new, perhaps they bunged a two pin diff in to make up for the lack of drivetrain slop from the rear end?
Post #850094 15th Aug 2020 10:40am
Despite what JLR has claimed and what has been written in various places it is apparent that 110s were being built with 2-gear diffs right to the end. Some have 4, most seem to have 2.
With the 2-gear diff in a 110 it isn't so much a case of "if" but "when" it fails, it simply isn't strong enough.
I don't know if the 130s were also random or if they all had 4-gear diffs.
Post #850095 15th Aug 2020 10:59am
miker
Impressively, my 2 pin front is 230,000 miles and 20 years old. It does have some play in it though...
Post #850105 15th Aug 2020 11:28am
jst
My 2010, 11my 110 had a 2 front diff, 4 pin rear.
My 2011 130 had 2 pin front, 4 pin rear. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #850112 15th Aug 2020 11:53am
Oldowner
I wonder whether it was the 110 hardtops / Hicaps that got the 4 pin front diff being as they were most likely to be worked hard and overloaded by Utility companies etc?
Either way I still can’t believe this end of line 110USW has been fitted with the total junk 2 pin, the cross-shaft has elongated the hole in the diff carrier, what a surprise.
Post #850125 15th Aug 2020 12:46pm
Mo Murphy
Look at the centre diffs they put in toward the end !
Glad mines old Very Happy
50 Shades of Pennine Grey
Post #850149 15th Aug 2020 3:09pm
Out of interest what is the typical life of Puma Defender diffs supposed to be? TheThunder Rolls🇬🇧🇺🇸
Post #850151 15th Aug 2020 3:13pm
What does the build spec show? or literature for that age vehicle from LR?
Surely there must be some claim for fraud?
Post #850168 15th Aug 2020 5:27pm
jst
my build spec shows 4 pin front!
ref hardtops utilities, i dont think so. 130 HiCap had 2 pin front Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #850170 15th Aug 2020 5:42pm
Pretty appalling that a 130 has a 2-gear diff.
A modern diff should be good for half a million miles or more ... except in a Defender. I'd expect rear diffs to last 250k or more, 2-gear front on a working 110, well mine failed spectacularly at about 70k.
Post #850173 15th Aug 2020 5:53pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
My 2015 USW has the standard 2-pin front so if they did put 4 pin diffs in, it wasn't in very many of them! ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #850199 15th Aug 2020 7:42pm
