Home > Technical > Puma squealing when accelerating HELP |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17450 |
Usually this is a split intercooler hose (normally the one directly over the steering box) but you say that these are new, which should rule that out unless of course you've fitted Britpart ones.
It could be a split in the intercooler itself, but the other common cause is a leak either at the flange between the turbo and the exhaust manifold or (slightly less commonly) the exhaust manifold and the head. The fact that you say it is worse when hot makes me suspect the manifold joints. |
11th Aug 2020 6:51pm |
pauldgray Member Since: 08 Aug 2020 Location: Hindhead Posts: 14 |
Thanks for that, the hoses are silicon and not britpart. The head was replaced a year ago so it could have something related to that with the manifold I guess. The only concern I have as well is I replaced the egr with a britpart product. Thanks for your help
11th Aug 2020 6:58pm |
Slipping aux belt? Ray
11th Aug 2020 7:26pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1917 |
Turbo seal I expect, Knakatanenga do an uprated one especially if yours has been remapped which creates higher EGT (exhaust gas temperature) nice easy DIY fix. 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
11th Aug 2020 8:10pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5729 |
Turbo gasket or failed turbo!!
Click image to enlarge |
20th Aug 2020 7:53am |
That would do it! Ouch.
20th Aug 2020 4:18pm |
All sorted now. Sold it and went back to a Td5
20th Aug 2020 4:25pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3317 |
Easy if the studs play nicely.. WARNING. This post may contain sarcasm. |
20th Aug 2020 4:28pm |
Need to do mine and I’m dreading it, my luck is poxed most of the time and undoubtedly one will snap!
Any tips? 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
20th Aug 2020 6:53pm |
If your luck is as bad as mine I would pay someone to do it or wait until you replace the turbo. WARNING.
20th Aug 2020 7:12pm |
