Home > Technical > Puma squealing when accelerating HELP
pauldgray
United Kingdom 2009 Defender 90 Puma 2.4 HT Java Black
Can anyone help, 2.4 tdci squeals like a supercharger at 2000 to 3000rpm, in any gear. It is very noticeable when hot. EGR has been changed, there are no leaks on the turbo, new inter cooler hoses. It does hesitate when accelerating hard when over 3000rpm. I’m baffled, anyone got an idea?
Post #849347 11th Aug 2020 5:50pm
Usually this is a split intercooler hose (normally the one directly over the steering box) but you say that these are new, which should rule that out unless of course you've fitted Britpart ones.
It could be a split in the intercooler itself, but the other common cause is a leak either at the flange between the turbo and the exhaust manifold or (slightly less commonly) the exhaust manifold and the head. The fact that you say it is worse when hot makes me suspect the manifold joints.
Post #849359 11th Aug 2020 6:51pm
pauldgray
Thanks for that, the hoses are silicon and not britpart. The head was replaced a year ago so it could have something related to that with the manifold I guess. The only concern I have as well is I replaced the egr with a britpart product. Thanks for your help
Post #849361 11th Aug 2020 6:58pm
mk1collector
Slipping aux belt? Ray
My build thread
Post #849370 11th Aug 2020 7:26pm
bear100
Turbo seal I expect, Knakatanenga do an uprated one especially if yours has been remapped which creates higher EGT (exhaust gas temperature) nice easy DIY fix. 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #849379 11th Aug 2020 8:10pm
landy andy
Turbo gasket or failed turbo!!
Post #851069 20th Aug 2020 7:53am
That would do it! Ouch.
Post #851155 20th Aug 2020 4:18pm
landy andy
All sorted now. Sold it and went back to a Td5 Rolling with laughter Rolling with laughter Rolling with laughter
Post #851156 20th Aug 2020 4:25pm
Zed
Easy if the studs play nicely.. WARNING.
Post #851157 20th Aug 2020 4:28pm
bear100
Need to do mine and I’m dreading it, my luck is poxed most of the time and undoubtedly one will snap!
Any tips? 2023 Defender L663 V8
Post #851176 20th Aug 2020 6:53pm
Zed
If your luck is as bad as mine I would pay someone to do it or wait until you replace the turbo. WARNING.
Post #851182 20th Aug 2020 7:12pm
