![]() | Home > Technical > Puma squealing when accelerating HELP |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17598 ![]() ![]() ![]() |
Usually this is a split intercooler hose (normally the one directly over the steering box) but you say that these are new, which should rule that out unless of course you've fitted Britpart ones.
It could be a split in the intercooler itself, but the other common cause is a leak either at the flange between the turbo and the exhaust manifold or (slightly less commonly) the exhaust manifold and the head. The fact that you say it is worse when hot makes me suspect the manifold joints. |
pauldgray Member Since: 08 Aug 2020 Location: Hindhead Posts: 14 ![]() ![]() ![]() |
Thanks for that, the hoses are silicon and not britpart. The head was replaced a year ago so it could have something related to that with the manifold I guess. The only concern I have as well is I replaced the egr with a britpart product. Thanks for your help
Slipping aux belt? Ray
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1953 ![]() ![]() ![]() |
Turbo seal I expect, Knakatanenga do an uprated one especially if yours has been remapped which creates higher EGT (exhaust gas temperature) nice easy DIY fix. 2023 Defender L663 V8
2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
Turbo gasket or failed turbo!!
That would do it! Ouch.
All sorted now. Sold it and went back to a Td5
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3348 ![]() ![]() ![]() |
Easy if the studs play nicely.. WARNING. This post may contain sarcasm. |
Need to do mine and I’m dreading it, my luck is poxed most of the time and undoubtedly one will snap!
Any tips? 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
If your luck is as bad as mine I would pay someone to do it or wait until you replace the turbo. WARNING.
