Home > Off Topic > MOT showed this - what does it mean?
Page 2 of 2 <12
jst
Is this forum turning into the most negative forum out there?
Maybe its been repaired and they didn't want it to rust again so put some preservative on it.
If they had welded on a plate and not done anything to it people would moan at that too. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #842081 6th Jul 2020 12:20pm
LandRoverAnorak wrote:
Supacat wrote:
Tap it with a hammer or use a fine flat fronted drift. If you damage the underseal and find the repair is perfect, just slap a bit more on, if you find the repair inadequate, it's all coming off anyway.
Given the advisories quoted, it appears the MoT testers wouldn't go that far.
And I thought they had to purchase a hammer for exactly that purpose?
Post #842092 6th Jul 2020 1:00pm
Perhaps they just don't like getting their tools dirty. The point though, much as JST has made above, was more about reaching the conclusion that if something is covered in underseal then it's automatically a sign of something bad. Darren
Post #842094 6th Jul 2020 1:09pm
bodstruck
Some testers can be either very picky or like to cover themselves. My 110 with all new suspension, fuel lines and a galv chassis had an advisory of 'general underbody corrosion'. When I asked about it the tester actually said it was a catch-all.
As has been said, probably fine but good to check.
I had a S3 which looked fine but someone had actually glued metal over the rust in the front crossmember. Probably took as long to do as a proper repair. Ended up cutting it all off and replacing the front 1/4.
Post #842096 6th Jul 2020 1:19pm
jst
I have seen a roll cage welded on with rtv 'lookalike weld' on the hard to reach spots. So there are cowboys out there but i dont think we should all assume the worst everytime. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #842098 6th Jul 2020 1:50pm
Procta
Re: MOT showed this - what does it mean?
CUE99T wrote:
Any help would be great to interpret what this means from 1 of a few cars I'm going to look at this week.
Nearside Rear Suspension component mounting repair covered in underseal (5.3.6 (a) (i))
Offside Rear Suspension component mounting repair covered in underseal (5.3.6 (a) (i))
vehicle chassis and under body wax oiled
any help would be good
Thanks in advance
Too me its just the mot tester been picky Censored , i pulled the last mot tester about something similar on my cars. Took them else where and no daft advisories like that. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #842122 6th Jul 2020 4:00pm
Page 2 of 2 <12
