Home > Off Topic > MOT showed this - what does it mean? |
And I thought they had to purchase a hammer for exactly that purpose? Click image to enlarge |
6th Jul 2020 12:00pm |
Perhaps they just don't like getting their tools dirty. The point though, much as JST has made above, was more about reaching the conclusion that if something is covered in underseal then it's automatically a sign of something bad. Darren
6th Jul 2020 12:09pm |
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 913 |
Some testers can be either very picky or like to cover themselves. My 110 with all new suspension, fuel lines and a galv chassis had an advisory of 'general underbody corrosion'. When I asked about it the tester actually said it was a catch-all.
As has been said, probably fine but good to check. I had a S3 which looked fine but someone had actually glued metal over the rust in the front crossmember. Probably took as long to do as a proper repair. Ended up cutting it all off and replacing the front 1/4. |
6th Jul 2020 12:19pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8033 |
I have seen a roll cage welded on with rtv 'lookalike weld' on the hard to reach spots. So there are cowboys out there but i dont think we should all assume the worst everytime. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
6th Jul 2020 12:50pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5173 |
Too me its just the mot tester been picky , i pulled the last mot tester about something similar on my cars. Took them else where and no daft advisories like that. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
6th Jul 2020 3:00pm |
