Home > Maintenance & Modifications > Electrical Fault
RLD
Electrical Fault
Ok as many of you know i have a 130 TD5 as just append temp gauge reads normal but put my foot down it drops to zero take my foot off and back up only done this once but the heater on and engine cut out would not start ok got recovered to my garage could not fined any faults on on so replaced ECU and still the same it runs ok but still has the fault any one any idea what it could be dont want to risk going out again till repaired .
Thanks Ray RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Post #840903 1st Jul 2020 9:00am
dorsetsmith
check earthing for ECU battery to chassis - chassis to body work bottom drivers seat box in side
Post #840910 1st Jul 2020 9:08am
RLD
Thanks yes done all that as well good lads in the garage but just stumped at the moment RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Post #840917 1st Jul 2020 9:18am
dorsetsmith
replace coolant sender
how old is starting battery Question if battery voltage to low when at starting load ecu will not fire the injectors
crank sender or its wiring will stop engine from starting
Post #840929 1st Jul 2020 9:42am
RLD
Good battery when back in garage stated with a little charge always been a good starter had it from new 17 years RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Post #840952 1st Jul 2020 10:51am
Martin
Site Admin
Ray, have a look here, try running a new ground/earth wire to the ECU ground stud in the seatbox.
https://www.defender2.net/forum/topic72414...auge+pedal  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #840964 1st Jul 2020 11:33am
RLD
Bow down Bow down Thumbs Up RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Post #841032 1st Jul 2020 2:38pm
RLD
Ok sorted now thanks for every one the input you put earth wire some where any way got it all back up and ruining thanks every one Bow down Bow down Thumbs Up RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
Post #842107 6th Jul 2020 2:54pm
Martin
Site Admin
Great news Mr. Green Mr. Green  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #842108 6th Jul 2020 2:56pm
