Home > Maintenance & Modifications > Electrical Fault |
RLD Member Since: 29 Jun 2007 Location: Lancs Posts: 858 |
Ok as many of you know i have a 130 TD5 as just append temp gauge reads normal but put my foot down it drops to zero take my foot off and back up only done this once but the heater on and engine cut out would not start ok got recovered to my garage could not fined any faults on on so replaced ECU and still the same it runs ok but still has the fault any one any idea what it could be dont want to risk going out again till repaired .
Thanks Ray RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear |
1st Jul 2020 8:00am |
check earthing for ECU battery to chassis - chassis to body work bottom drivers seat box in side
1st Jul 2020 8:08am |
Thanks yes done all that as well good lads in the garage but just stumped at the moment RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
1st Jul 2020 8:18am |
Good battery when back in garage stated with a little charge always been a good starter had it from new 17 years RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
1st Jul 2020 9:51am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6601 |
Ray, have a look here, try running a new ground/earth wire to the ECU ground stud in the seatbox.
https://www.defender2.net/forum/topic72414...auge+pedal 1988 90 Td5 NAS soft top 2015 D90 XS SW |
1st Jul 2020 10:33am |
1st Jul 2020 1:38pm |
Ok sorted now thanks for every one the input you put earth wire some where any way got it all back up and ruining thanks every one RLD fabricator of Hidden Winch Mount for D3/4 roof racks jerry can holders CB aerial mounts and much more and agent for Helsport Tents and gear
6th Jul 2020 1:54pm |
Great news 1988 90 Td5 NAS soft top
2015 D90 XS SW |
6th Jul 2020 1:56pm |
