Home > Puma (Tdci) > First ever defender, I have a few questions!
Jeffdahmer
2013 Defender 110 Puma 2.2 XS CSW Alpine White
Hey guys, recently picked up my first defender, a puma 110 and I have a few questions...stupid questions:
Is the 4x4 gear stick suppose to block the cup holders?
Where do you store the wrench and jack?
[/url]
Post #837189 14th Jun 2020 6:33pm
Stacey007
Hello
Welcome Smile
It looks like an after market cubby /armrest possibly with a amp under it? it does appear to block the cup holder. Mine doesn't and its a std bottom part?
Have you a picture of the cubby?
Jack etc, check under passenger seat if those bases remove as you have a cubby under each seat. The passenger one has more room with the battery in there, I have the bottle jack and jump leads etc in there. Then I have a pelican case in the rear with tow ropes, gloves, torch, sockets, etc etc Smile
Post #837192 14th Jun 2020 6:44pm
Pacha
Some of the 'specialist' re-fits can screw up the less than ideal ergonomics. That looks like a Bespoke conversion? Rgds.
Chris
Post #837196 14th Jun 2020 6:53pm
Jeffdahmer
Stacey007 wrote:
Hello
Welcome Smile
Ah thanks for the reply!
Yeh it’s an aftermarket cubby, there’s a sub in the back, and the cubby is capped under the lid so I assume there’s an amp in there too. I’ll take a picture for you.
Post #837199 14th Jun 2020 7:01pm
Jeffdahmer
Yeh it’s a bespoke conversation. So it looks like they just put a cubby box in that’s too long?
Post #837201 14th Jun 2020 7:02pm
DG123
Good luck with the new toy
That’s a big cubby Smile
Depending on how long it is, you may be able to move it backwards. It’ll just be bolted onto the transmission tunnel.
EDIT - just seen it’s got a sub on the back. Compromise between cupholder access and passenger legroom Neutral 2012 110 XS SW Orkney Grey
2003 D2 Td5 Black [SOLD]
Post #837204 14th Jun 2020 7:08pm
bear100
the cubby is held in place (well the original anyway) with 4 bolts, it would be an easy job to relocate them, the panel under the box is removable too
Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #837207 14th Jun 2020 7:19pm
Jeffdahmer
Aaaahh perhaps it’s just normal size then and the previous owner shifted it forward to give more rear leg room. Thanks for the tip!
Yeah I love it already and already have a long list of tweaks I want to make
Post #837209 14th Jun 2020 7:21pm
The standard position for the cubby box just clears the transfer box lever:
 Darren
Post #837228 14th Jun 2020 9:07pm
AMBxx
I had to move mine back when I fitted an under-cubby safe. 2nd row middle seat rarely used, so no great loss. Dogs don't seem to mind either!
Post #837318 15th Jun 2020 12:24pm
ChrisCSL
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Welcome Jeff,
Please share some pics of your truck. It would be interesting to see a 'Bespoke'.
Chris
Post #837320 15th Jun 2020 12:44pm
X4SKP
Re: First ever defender, I have a few questions!
Jeffdahmer wrote:
Hey guys, recently picked up my first defender, a puma 110 and I have a few questions...stupid questions: Is the 4x4 gear stick suppose to block the cup holders? Where do you store the wrench and jack?
[/url]
Welcome Jeffdahmer ... 1st no stupid questions for a 'newbe', (you'll learn as you go Shocked )
Your centre consul is certainly custom and looks to be 30-50mm further forward than standard
may also be a little higher, take off and see the ICE kit that has caused this to relocate if possible.
Wrench and Jack (standard issue bottle jack) are normally under the passenger seat.
A move to an upgraded bottle jack (typical) or a double install battery system often sends the bottle
jack into the main cabin...somewhere.
Good luck SKIP
Post #837343 15th Jun 2020 3:10pm
NinetyTD4
Wales 2012 Defender 90 Other SW Keswick Green
[/url]
Wrench and jack are put by factory in the box under the left seat. And as others have noted, that ain't no standard cubby box. That far forward is even too far for the ordinary landrover production tolerances Wink, so most probably custom made. It also seems higher and what is that odd strap in the front, can the box be opened forward? The cushion on top is also not Defender'ish - much too comfy. Never forget: cars have owner, Landrover have field service personnel.
Post #837370 15th Jun 2020 6:14pm
Pacha
There is a Bespoke 90 that lives near to me, walking past it earlier and having a peek, it's the cubby box arrangement that they use that is the issue. Rgds.
Chris
Post #837373 15th Jun 2020 6:21pm
cold
It doesnt cover the cup holder in my Bespoke but my cubby looks to be a std xs cubby with padded top and sub box underneath hence the height
Post #837389 15th Jun 2020 7:12pm
