Home > Puma (Tdci) > First ever defender, I have a few questions! |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3750 |
Hello
Welcome It looks like an after market cubby /armrest possibly with a amp under it? it does appear to block the cup holder. Mine doesn't and its a std bottom part? Have you a picture of the cubby? Jack etc, check under passenger seat if those bases remove as you have a cubby under each seat. The passenger one has more room with the battery in there, I have the bottle jack and jump leads etc in there. Then I have a pelican case in the rear with tow ropes, gloves, torch, sockets, etc etc |
14th Jun 2020 6:44pm |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 |
Some of the 'specialist' re-fits can screw up the less than ideal ergonomics. That looks like a Bespoke conversion? Rgds.
Chris |
14th Jun 2020 6:53pm |
Jeffdahmer Member Since: 14 Jun 2020 Location: United kingdom Posts: 31 |
Ah thanks for the reply! Yeh it’s an aftermarket cubby, there’s a sub in the back, and the cubby is capped under the lid so I assume there’s an amp in there too. I’ll take a picture for you. |
14th Jun 2020 7:01pm |
Yeh it’s a bespoke conversation. So it looks like they just put a cubby box in that’s too long? |
14th Jun 2020 7:02pm |
DG123 Member Since: 29 Aug 2015 Location: North West Posts: 133 |
Good luck with the new toy
That’s a big cubby Depending on how long it is, you may be able to move it backwards. It’ll just be bolted onto the transmission tunnel. EDIT - just seen it’s got a sub on the back. Compromise between cupholder access and passenger legroom 2012 110 XS SW Orkney Grey 2003 D2 Td5 Black [SOLD] |
14th Jun 2020 7:08pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1915 |
the cubby is held in place (well the original anyway) with 4 bolts, it would be an easy job to relocate them, the panel under the box is removable too
2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
14th Jun 2020 7:19pm |
Aaaahh perhaps it’s just normal size then and the previous owner shifted it forward to give more rear leg room. Thanks for the tip!
Yeah I love it already and already have a long list of tweaks I want to make |
14th Jun 2020 7:21pm |
The standard position for the cubby box just clears the transfer box lever:
Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
14th Jun 2020 9:07pm |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1031 |
I had to move mine back when I fitted an under-cubby safe. 2nd row middle seat rarely used, so no great loss. Dogs don't seem to mind either!
15th Jun 2020 12:24pm |
ChrisCSL Member Since: 10 Aug 2019 Location: Berks Posts: 186 |
Welcome Jeff,
Please share some pics of your truck. It would be interesting to see a 'Bespoke'. Cheers Chris |
15th Jun 2020 12:44pm |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
Welcome Jeffdahmer ... 1st no stupid questions for a 'newbe', (you'll learn as you go ) Your centre consul is certainly custom and looks to be 30-50mm further forward than standard may also be a little higher, take off and see the ICE kit that has caused this to relocate if possible. Wrench and Jack (standard issue bottle jack) are normally under the passenger seat. A move to an upgraded bottle jack (typical) or a double install battery system often sends the bottle jack into the main cabin...somewhere. Good luck SKIP https://www.defender2.net/forum/topic83242.html |
15th Jun 2020 3:10pm |
NinetyTD4 Member Since: 22 Apr 2011 Location: North Posts: 397 |
Wrench and jack are put by factory in the box under the left seat. And as others have noted, that ain't no standard cubby box. That far forward is even too far for the ordinary landrover production tolerances , so most probably custom made. It also seems higher and what is that odd strap in the front, can the box be opened forward? The cushion on top is also not Defender'ish - much too comfy. Never forget: cars have owner, Landrover have field service personnel. |
15th Jun 2020 6:14pm |
There is a Bespoke 90 that lives near to me, walking past it earlier and having a peek, it's the cubby box arrangement that they use that is the issue. Rgds.
Chris |
15th Jun 2020 6:21pm |
cold Member Since: 15 Dec 2018 Location: Yorkshire Posts: 118 |
Click image to enlarge It doesnt cover the cup holder in my Bespoke but my cubby looks to be a std xs cubby with padded top and sub box underneath hence the height |
15th Jun 2020 7:12pm |
