Home > Technical > It was all going too well - C-19 rebuild woes, caliper bolts
Mean Green
It was all going too well! Like many others I have been using my time 'off' on furlough to rebuild my 1993 90 onto a galv chassis. Until now it has been easier than I expected. I am now on the rebuild stage and tackling the brakes. I am replacing the entire rear system as the calipers are badly rusted. First caliper bolt dissolved as soon as I put a spanner on it - I didnt even get a change to put any sort of pressure on it before it rounded. I knocked a smaller size socket onto it and it got a good hold but would not budge, until it slipped and rounded the head. Bolts 2 and 3 were very tight but came out with a long bar (and extension). The last bolt snapped as soon as I put the socket on - I didnt even get the chance to put the long bar on it.
So I now have 1 caliper off, the hub stripped down to access the bolt hole and a bolt snapped inside the hole. The second caliper cannot come off as the head is rounded.
Help!! I have drilled out about a 6mm or so hole in the snapped bolt and tried stud extractors and a bit of heat (I didn't have the heat when I snapped them). It wont budge and I am scared the stud extractor breaks. I have not attempted anything on the rounded head yet.
Any suggestions or experiences to draw on??
Post #836375 10th Jun 2020 4:58pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Can you get access to weld a nut onto it?
Post #836376 10th Jun 2020 4:59pm
Mean Green
The rounded head yes, but the other one has snapped flush with the face (Oh and I cant weld)
Post #836380 10th Jun 2020 5:02pm
T140
Scotland 2007 Defender 90 Td5 HT Zambezi Silver
you can place a nut over the one that's broken flush and weld through the nut onto the sheared bolt, the heat from the weld should help loosen the bolt nobody is perfect but being Scottish is a start
Post #836387 10th Jun 2020 5:39pm
landy andy
Cut the calliper off. They are fairly cheap, and probably need to be replaced after so long on there.
Post #836414 10th Jun 2020 7:20pm
Pacha
Just paid £32 for a new rear caliper. Rgds.
Chris
Post #836415 10th Jun 2020 7:25pm
Devon-Rover
United Kingdom 2014 Defender 110 Puma 2.2 USW Aintree Green
Irwin bolt grips is my go to when dealing with festering caliper bolts. Thumbs Up Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #836419 10th Jun 2020 7:40pm
Harry.O
With the bolt that has snapped flush with the caliper, get a couple of left-handed drill bits then continue to drill it out with the drill in reverse, eventually as you work up the sizes of drill bits and the bolt starts to thin from the inside out, it will start to unscrew. I've used this method on a few TD5 exhaust manifolds with good success. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #836481 11th Jun 2020 8:15am
Pugit666
United Kingdom 1998 Defender 90 300 Tdi CSW Alpine White
This happened to me too. I split the Caliper and drilled the bolt out from the front. Took me about a fortnight haha
Post #836966 13th Jun 2020 10:53am
