![]() | Home > Technical > It was all going too well - C-19 rebuild woes, caliper bolts |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1039 ![]() ![]() ![]() |
Can you get access to weld a nut onto it?
Mean Green Member Since: 15 Sep 2011 Location: South Ayrshire Posts: 280 ![]() ![]() |
The rounded head yes, but the other one has snapped flush with the face (Oh and I cant weld)
T140 Member Since: 15 Mar 2016 Location: Ayrshire Posts: 177 ![]() ![]() ![]() |
you can place a nut over the one that's broken flush and weld through the nut onto the sheared bolt, the heat from the weld should help loosen the bolt nobody is perfect but being Scottish is a start
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5871 ![]() ![]() |
Cut the calliper off. They are fairly cheap, and probably need to be replaced after so long on there.
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781 ![]() ![]() ![]() |
Just paid £32 for a new rear caliper. Rgds. Chris |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 925 ![]() ![]() ![]() |
Irwin bolt grips is my go to when dealing with festering caliper bolts.
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 723 ![]() ![]() ![]() |
With the bolt that has snapped flush with the caliper, get a couple of left-handed drill bits then continue to drill it out with the drill in reverse, eventually as you work up the sizes of drill bits and the bolt starts to thin from the inside out, it will start to unscrew. I've used this method on a few TD5 exhaust manifolds with good success. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
Pugit666 Member Since: 04 Mar 2020 Location: York Posts: 43 ![]() ![]() ![]() |
This happened to me too. I split the Caliper and drilled the bolt out from the front. Took me about a fortnight haha
