![]() | Home > Off Topic > Cutting oil |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4784 ![]() ![]() |
I know cutting oil must be specifically formulated for the job but if I wanted to drill into a Defender bumper and had no cutting oil to hand would engine oil or gear oil do as a substitute? 1982 88" 2.25 diesel
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4262 ![]() ![]() ![]() |
I don’t know about gear or engine oil, but WD40 works ok in a pinch. 2007 110 TDCi Station Wagon XS
Thank you. Like everyone else I would have some WD40 handy.
![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1852 ![]() ![]() ![]() |
engine oil or gear oil works well for hand drilling or pillar drilling in an old fashioned oil can...
HTH Keith |
And like WD40 I do have engine oil and gear oil to hand.....
Eh, just out of curiosity of course. If cutting all were needed in an emergency, I am told Anne Summers stock "lubricating oil". Would that do? And no, unlike WD40, engine oil and gear oil I do not have that on my work bench.. 1982 88" 2.25 diesel
The Anne Summers stuff is supposed to aid penetration...….. 1982 88" 2.25 diesel
It would be OK at the front for spotlights.
For a tow bar you'd need booty lube....... |
Does the Anne Summers website have user reviews like Screwfix? 1982 88" 2.25 diesel
Probably - dare you to leave one stating how easy it made drilling and screwing on your defender.......
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1238 ![]() ![]() ![]() |
Given I drilled through my 12mm thick rear cross member with a 13mm drill with no lube I doubt you're going to need it
![]() No pilot drill either, well it was sort it built in being a Dewalt Extreme 2 drill bit. Those things are great for thick steel! Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
So no lube needed, just grind away...
![]() Stop for a break now and then if things get hot? Better remember to tell the Mrs, "Don't touch that, it might be hot after all of that grinding". So after a short break I'll be ready to resume. As things will .have cooled down I'll be able to tell the Mrs, "Hold that while I get it centred". Oh and no hammer action, just a steady grind. Yep think I have it now. I'll let you know how I get on.... 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
If you're still referring to drilling metal then if it's got hot you're done for. Ed
